Originally Posted by MikeH
How much can we expect to tpay for this P1900 Unit? Is there another that can be used at this time?
Ok thanks, just an idea. By the time your battery gets to 10.6 you will proberly not start the car. I was thinking more along the line of if you leave it on stand by it drops the connection before it gets to the point of no start. As I have not got out of the buying stage into the building stage yet. I don't know what power needs I have so have not looked to deeply into PSU specs yet.(pc not mac)Originally Posted by MikeH
EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
Hi Mike i've sent off email to suppliers to see if they have any kind of adapter that might connect to the Mac mini power supply plug.Originally Posted by MikeH
I'll keep you updated on this.
The ACPI Header connector is something i'm curious about
This is just 2 wires plugging into the board? like a power switch on the PC?
besides the connector you just need wires nothing else in between?
Can you tell me how wide the pitch is between the 2 pins?
It is 2 pins m i correct?
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Found a useful link for us, for when the car is turned off and the computer is in sleep mode. DIY UPS
Sorry guys....I'm out of town this week...I'll try to answer some of these questions early next week
MikeH
My idea from the get go was a 2 battery isolator system. Even if I was gonna stick with a WinTel machine. Truth be told having a carputer is awesome, but powering it is a *****. Having a second batt (optima) is a good thing just so you can have a piece of mind. NOw as for the MAC side of things, its always been known sleep draws power, and a lot considering it vs hibernate. But with a second batt, and those of us who drive every day even a little bit, you can put it into sleep when you come home and itll be RIGHT THERE as you left it when you come back. OSX starts up quick, but its much quicker to come back from sleep, power draw is negligable when u have a second battery. If you go on vacation, turn it off. Duh.
(0.0%-) starting over
iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
I know you can run Cron jobs in BSD Unix....do they work if the computer is asleep? If so, could you program it to wake and see if some kind of state file exists that indicates the computer or the car has been on in the last 24 hours?
You could program in that if it was more than, say, 48 hours since last use, shut down -or for that matter, maybe check some kind of battery voltage indicator and shut down based on that.
Want to:
You probably want "at" rather than "cron," since 'at' is for one-shot program runs, where cron is for repetitive programs.
No, cron jobs do not run while the computer is asleep.
However, on some PC systems, you can set a "wakeup" timer. Can the mini-mac do this? I don't know.
My scenario: set an 'at' job 2 hours in the future, and put the computer to sleep with a 115-minute timer. At the end of 115 minutes, it wakes up. At 120, it turns itself off. Obviously, you'd have to figure some way to tell if the user is bringing the computer back, and remove the 'at' job.
Christopher Jastram
http://www.livingresource.net/
cej102937
you can set a wakeup timer in OS X, but it requires a specific time to shutdown or wake up...its not a timer.
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
Here's the control panel for the energy saver panel. It wakes and shuts down/sleep the computer on a certain schedule, either daily, weekdays, weekends, or a specific day. I'd think you could set an Applescript to run and then shut down the computer if you wanted to.
Want to:
