hi there,
nice idea of placing the monitor. can you give me the bmw part number for the cupholder so i can order it here in austria?
thanks,
markus
The screen mount looks awesome. I have some friends with a new mini, so I'll be trying to talk them into having an install...
FociMan
Ford Focus Collection
EPIA M10K / 512Kb / Creative Audigy NX USB
8" touchscreen
D-Link USB Radio
USB GPS Mouse
Bluetooth GPRS Web Connection
Centrafuse Beta2 / MapMonkey
hi there,
thanks,
markus
Did you see this Mini in a Mini?
mac2go
Very nice! Though I don't really see the point in the two decently sized LCDs (what are those... 15"?) behind the front seats: who the heck is sitting back there??Originally Posted by defender90
Kidding... that's more of a show car setup, though I'm sure it would entertain any rugrats I tucked into the back.
What screen is he using up front? Looks like a motorized, retractable touchscreen.
yes, seems so.. but i don't like these b/c you never know when to refuel ;-)
markus
hi fireant, i finally decided to place the display in my cooper as you did it. could you please post some close up pictures of how you mounted the cupholder to the display?
thanks in advance!
I will try to take some closer pics for you, but understand if you don't have the exact same monitor it may not work the same. I used a hole on the side of my monitor where the stylus was to insert the alluminum rod near the top. I had to open up the monitor and I think even drill a little bit to allow the rod to insert. Then i had to insulate the alluminum from making contact with the pcb by covering the area with electrical tape. Please note you will void the warranty on your monitor when you open it and the lilliput monitors are sensitive, the ribbon cable inside can be damaged or unseated easily.
Good Luck!
Mike
05 MINI Cooper Cabrio "Mac MINI"
progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
today, i ordered the cupholder for my cooper. it is here 43,95eur.. pretty expensive, imho.. how much is it in the us?
and which monitor are you using? is it a touchscreen? are you satisfied with the model?
markus
I am using the 7" Lilliput Touch Screen XGA Car Monitor (Model 629GL 70 P/C/T). (purchased from ebay) It had problems with the cable right after I received it. I think it is an ok Monitor but can be dificult to see in a convertible. It does have the touch screen which I really like, but lowers the brightness slightly and provides more of a mat finnish to the screen. (creates a diferent kind of glare)
It ended up that I cut the cable connector out that was bad and soldered the wires together. This actually helped reduce the bulk of connectors that would have been visible 3" below the screen. Very small wire to work with though. It took hours to do.
Good luck!
Mike
