Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 83
Thread: Mac Mini MINI
  1. #41
    Newbie Montanaja's Avatar
    Jul 2005
    Ypsilanti, MI
    Power source?
    How hard was it to wire up the power source on the MINI COOPER?
  2. #42
    Low Bitrate FireAnt's Avatar
    May 2004
    Houston, Texas
    Very easy! I ran a fused wire from the battery and another from the accessory plug that is switched by the ignition.
    Mike F.
    05 MINI Cooper Cabrio "Mac MINI"
    progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
  3. #43
    May 2004
    Houston, Texas
    Here is the latest! I've just heard my car is in the September "MacWorld" magazine!
    Here is my updated front end using CCAR with a color change to match my car.
    Mike F.
  4. #44
    Aug 2005
    quick question... what do you do when you want to turn your car off? does the mac turn off or do you have to wait till it turns off before you can shut off the car? and when you turn on the car, what happens then?
  5. #45
    May 2004
    Houston, Texas
    Quote Originally Posted by 786mine
    I just turn my car off. After 45 seconds the power to the Mac mini is then cut off by the p1900 carnetix power supply.(unfortunately this is like pulling the plug) Then when I turn my car back on the power supply sends a signal to the computer to turn it on. This has worked great so far. I can also enable the sleep mode which the power supply would just put it to sleep. Instant wake up that way. But, computer will draw power in the sleep mode.
    Hope this helps
    Mike
  6. #46
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    hmmmm...couldn't it be setup to issue a signal to the mobo to power down?
    I don't know much about Macs, but my M1-ATX seignals the mobo to turn off before cutting all power...I get a smooth shutdown every time.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  7. #47
    May 2004
    Houston, Texas
    Quote Originally Posted by ITL
    No, there is no shut down by the power button for the mac. It will only sleep by the power button.
    Mike
  8. #48
    Feb 2005
    if you go into power settings in OSX you can set it up so it automatically reboots after a power failure. in this case, shutting the car off. so when you turn the car off, it automatically reboots. since osx is so stable and can handle this kind of abuse easily, it shouldn't be a problem.
  9. #49
    Aug 2005
    Quote Originally Posted by simon_C
    but what is a good way for windows based?
  10. #50
    Feb 2005
    dont know, i dont use windows.
  1. First Mac Mini in a Land Rover
    By dmonckton in forum Show off your project
    Last Post: 08-14-2005, 07:53 PM
  2. Help Needed: Mac Mini Carputer
    By dazuck in forum MacCar
    Last Post: 03-12-2005, 11:30 AM
  3. Uses for a Mac mini...
    By migel628 in forum Off Topic
    Last Post: 02-16-2005, 02:22 PM
  4. The Mac mini setup...
    By bubbalito in forum MacCar
    Last Post: 02-03-2005, 03:33 PM
  5. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 01:25 PM
