Jsut thought i would let you know, Makro (UK) has a Trust laptop DC-DC that will output from 15V to 20V at 6A and 20V to 35V at 5A. that is a 120W - not bad for £24.99+VAT. more than enough for your MAC minis.
Originally Posted by iKenndac
Awesome...this is exactly what I was looking for to replace to aging ibook....btw, as far as why Apple didn't combine the negative and the ground on the same wire....this is due to the fact that the only source for a ground/earth connection when using the power brick is the house's earth ground. This means that it needs to have a seperate ground wire that passes from the metal chassis of the mac mini through the power brick and to the house's ground. In automotive applications, the chassis of the car is ground, however to ease wiring, they use this ground/chassis as a the negative side of the electrical system via a short cable connecting the negative side of your battery directly to the chassis. Due to this, by seperating the ground and the negative on the power going to the mac mini while in the vehicle, you are just duplicating work since both the "negative" power going to the mac mini as well as the chassis ground for the vehicle are connected together. Although you can combine them, since the other side of the connection (the side of the cable going to the mac mini) has it seperated, you will have to have a jumper going from the ground to the negative similar to the way the control wire is wired with the resister, however for the ground, we just want a straight wire.
