Results 1 to 10 of 13
Thread: Rayming TripNav GPS?
    Low Bitrate FireAnt's Avatar
    May 2004
    Houston, Texas
    I received my TN-200 Rayming tripnav GPS yesterday and spent hours last night trying to get my MacMini to recognize it. Has any one got this GPS receiver to work with a MacMini?
    They list it as OS X compatible and I downloaded the drivers from their site and a newer driver from another site.
    The problem is the Virtual Com Port is not loading and showing up.
    I manually unloaded drivers as they recommended through the terminal and reloaded several times. So much for easy with a Mac
    I also tried plugging it in directly to a free usb port on the MacMini and through a powered hub. No Luck!
    Any Help? At least Route 66 software loaded ok. Just no GPS success.
    Another Question: How do you put icons on the desktop?
    Thanks,
    Mike
    MINI MacMini
    05 MINI Cooper Cabrio "Mac MINI"
    progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    If its USB, just try another computer (including PC to see if hotplug detected).
    Mac Car Moderator kandyman676's Avatar
    Maryland
    I actually have the same unit at home. I have not hooked it up to my mac yet since I've been playing with it on my PC tablet. The drivers for PC worked as intended and automatically did the virtual com port.
    I'll try to hook mine up before/during the weekend, but i just got back from a 3-day conference and my office job has a big *** pile that built up while i was away.
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
    May 2004
    Houston, Texas
    Still no luck with my GPS. (after hours of trying). I can get it to work on my Toshiba Notebook with WinXP but not on the Mac Mini. This could be a real concern for everyone.
    The virtual Com Port Software is not working with the MM. Has anyone got a GPS to work with a Mac Mini?
    Please tell me what Virtual Com Port Software you are using. Am I really the only person trying to use a GPS with a Mac Mini?
    Please help.
    Mike
    MINI Mac Mini
    ps, I know people use this GPS with other Macs, but I am only interested in if it works with a Mac Mini. Or any GPS with a Mac Mini
    Maryland
    Quote Originally Posted by FireAnt
    Please help.
    Mike
    MINI Mac Mini
    I will still test mine on a Powerbook to make sure it is not just a Mac issue or a Mac model issue. in addition, have you contacted Rayming tech support with your problem? I know their sales and tech support are pretty good after talking with them several times before making a purchase of mine since it was re-certifed off ebay by them.
    May 2004
    Houston, Texas
    I spoke to someone from there and got a little help. Like try the drivers on the disk that came with it, not the downloadable drivers. They were in an .exe file that couldn't even be opened on my mac. I had to run it on my PC to get it to expand the mac osX drivers and they were the same as the down loadable ones.
    The problem is the Virtual Com Port (VCP) is not working correctly with the MacMini. The reciever does work as I have tried it with my notebook PC. The receiver also works with Mac Notebooks as the guy at Rayming said they have thousands of people using them. (apparently no one with a MacMini )
    The instructions go into detail about reenumerating the port using an editor on one of the files and making sure ownerships are set correctly using terminal and some commands that I can't get to run.
    Thanks,
    Mike
    May 2004
    Houston, Texas
    It Works!!
    I got it to work! Finally!
    I had to use the following instructions and it fixed it.
    . Enforce the proper ownership and permissions on the driver files.
    a. Bring up a terminal
    Appliction->Utilities->Terminal
    b. Change your working directory to the driver directory:
    cd /System/Library/Extensions
    c. Change the owner for all files and directories of this driver to root:
    sudo chown -R root FTDIUSBSerialDriver.kext
    d. Change the group for all files and directories of this driver to wheel:
    sudo chgrp -R wheel FTDIUSBSerialDriver.kext
    e. Change permissions for all files to 644:
    sudo find FTDIUSBSerialDriver.kext -type f -exec chmod 644 {} \;
    f. Change permissions for all directories to 755:
    sudo find FTDIUSBSerialDriver.kext -type d -exec chmod 755 {} \;
    Mike
    Maryland
    Looks like it was just some stupid permission problems, which is good to hear it was not a Apple mini-only thing! Thanks for sharing on how you fixed this Mike:-)
    Jan 2005
    Fairfield County, CT
    BTW, just right-click (or control-click if you only have one button) on the Route 66 icon and make an alias, and drag the alias to the desktop.
    Newbie MvF9884's Avatar
    Mar 2005
    post pics of the route 66 interface
    how do you like route 66, is there an auto-follow when used in conjunction with the gps. otherwise is is difficult to follow your path as you go?
    just want to hear an opinion on mac GPS as opposed to PC
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 05:54 AM
  2. OEM GPS mod. Writeup + Pics
    By IntellaWorks in forum Hardware Development
    Last Post: 07-04-2006, 02:59 AM
  3. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 12:11 PM
  4. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 01:40 AM
  5. FS: Rayming TN-200 GPS Receiver w/ IGuidance 2.0
    By phatrabbitzz in forum Classified Archive
    Last Post: 02-02-2005, 08:09 PM
