Results 11 to 20 of 21
Thread: Xenarc 700TSV @ 800x480 on a Mac mini?
  1. #11
    Newbie 4thChild's Avatar
    Sep 2005
    Talking
    The MacPac is the new power cable to be used between the CarNetix CNX-P1900 power regulator and the MacMini. The cable lets you plug in the MacMini and not tear up the power brick, hence, I can leave the power supply in the car and bring in the Mini when I want to play inside!! Hope that helps.
  2. #12
    AMP Creator aychamo's Avatar
    Jun 2006
    Does it do anything about automatically shutting down the mac?
  3. #13
    Sep 2005
    The P1900 does not the cable. Visit www.carnetix.com and check out the CNX-P1900 Power Supply for all the details. I have not installed this PS yet, but from what I read, these guys have covered the bases pretty well.
  4. #14
    Dec 2005
    Hi is liliput touch screen also have 800 x 480 resolution option?
  5. #15
    May 2007
    Quote Originally Posted by 4thChild View Post
    You shouldn't talk unless you own one. The P1900 and 2140 don't do anything about shutdown on a mac mini. View the carnetix forum and see the popular thread 'shutdown on mac mini'. You'll find there is no solution. The best that can be done is standby.
    I have been hoping they would fix this for a while now but they have not yet. They claim they are not mac developers and their usb driver is not supported on mac. However, one guy was able to make a mac version of their program (severely crippled) that does talk to the P2140, so it proves that they are wrong and it can be done. However, that doesn't help you with shutdown.
    To answer the origiginal question, I use the macpac to send signals from teh 2140 to the mac mini. However the signal can only do exactly what pushing the power button does. Go into and out of standby. Note to other mac users: Mac mini does NOT shut down when you push power, standby only. I hope they fix this in leopard.
  6. #16
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by MacVroom View Post
    We've finished the AppleScript to easily change the Mac mini's resolution to 800 x 480 upon startup. The download and instructions can be found here...
    http://www.macvroom.com/node/39/
    It's too bad cscreen isn't still available.
    Does anyone know another solution?
  7. #17
    Constant Bitrate onepuff's Avatar
    Jan 2006
    i think i have a copy of cscreen. i can send it to you if you want.
  8. #18
    Jun 2007
    I wouldn't mind if you were willing.
    Unless you know another way to make the resolution come up at 800 x 480 at start up.
  9. #19
    Jun 2007
    I'm looking at another program called SwitchResX.
    http://www.madrau.com/
    Looks like it solves all my issues.
  10. #20
    Newbie Nissan4LIFE's Avatar
    Mar 2008
    Temecula, California
    ^ Hey is SwitchResX pretty easy to setup or do we have to configure it like before with cscreen. I just want to find out if you had any difficulty setting it up with Leopard before I download it. Thanks
  1. Replies: 6
    Last Post: 09-28-2007, 03:50 AM
  2. First Mac Mini in a Land Rover
    By dmonckton in forum Show off your project
    Last Post: 08-14-2005, 07:53 PM
  3. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 01:25 PM
  4. Xenarc 700TSV 800x480 Support
    By auto_robotics in forum LCD/Display
    Last Post: 08-27-2004, 01:33 PM
  5. Has anybody got 800x480 to work with ver2 xenarc?
    By ChrisC in forum LCD/Display
    Last Post: 10-25-2003, 05:28 PM
