Banjamin,
If .02 is working well...should we go ahead and install .03? Or is this rev for a specific bug fix?
I think most folks use 600x800.
COuld you please post the ~/Library/Logs/CrashReporter/CCarProject.log file so i can figure out where the bugs are. THe ~/ means you home dirOriginally Posted by FireAnt
It was made to run on 800x480, but no one ever gave me what the NORM is so i assumed it was 800x480. But if everyone runs 800x600 then there is 120 more pixels of fun :P
Banjamin,
MikeH
Well then 800x600 is, unless someone else says other wise.Originally Posted by MikeH
I am in the proccess of changing things/adding new features that are requested, so each version that i will release (probably every night for a while) will be a bug fix and or add a new features. This time around i addded a loading screen, threaded the loading, and the off move off screen button(the ugly orange thing on the controller).
I havn't heard back from anyone that was having loading troubles with the first release, did .03 fix it?
I went straight to .03 on my MM and it worked great, no problems.![]()
My most sincere thanks.![]()
Carputer status: [-*---------]
Im thinking laptop...
Do you think it is possible to ad a phonebook, based on addressbook? Using a bluetooth gsm when connected?Originally Posted by BenjaminS
sounds possible, but thats later on down the road, and if someone wants to buy me a blue tooth phone to test it withOriginally Posted by defender90
Isn't the native res of the 7" screens 800 x 480? Seems that would be the most logical...Originally Posted by MikeH
Ok now its 50/50 ha, I am going to start a thread about this and see what happens.Originally Posted by dmeyer
Mike, your sig says you're running a 7" Lilliput, isn't the native res 800x480? Do things look squished? I am only in the planning stages of an install and have yet to get one...just going from native resolution specs.
Great work Benjamin !!
I have tested 0.3 on powerbook (G4 512M) on fully patched 10.3.9 using a library of approx 2000 (11GB music) no dramas/crashes or anything else to report.
Btw. is the little icon on the top right (for settings?) implemented ? as it does not respond to moi.
Again keep up the GREAT work !!
