Results 1 to 8 of 8
Thread: Using steering wheel controls to control mini mac?
    May 2005
    Is there a way to have your factory steering wheel controls ie Volume and Track to control mp3's or cd on mini mac?
    Aug 2004
    funny. the top thread is my exact thought for coming to the forums tonight. i have a miniITX winblows pc ready for my car, but would definitely prefer a mini mac...if route 66 gets better
    as far as steering wheel control, i was going to use ibus (i have a 2000 bmw), via serial interface in the trunk. i would have to buy a usb serial adapter, but those are real cheap online. the only thing i would need is to go is write some serial interface code, but since the one i have for windows is open source, it shouldnt be too bad. does your car have any sort of serial connectivity options? (look on the windows threads)...
    -avidan
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    You can always cut open the factory controls and connect into a USB inbterface card, keyboard controller, USB gamepad etc if you don't have a system like ibus.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    May 2004
    The Netherlands
    I have been looking for the same. I found out that for several brands, there are converters on the market, which convert the signals from the steeringwheel to infrared.
    example
    Together with an ir receiver and software for the Mac, like this:
    IRTrans + iRed
    I think this should work
    edit: these also work with other car brands.
    Low Bitrate BenjaminS's Avatar
    Mar 2005
    Quote Originally Posted by avidan
    -avidan
    If you do get around to porting it are you going to release the code to the public
    OT: are smilies an acceptable form of punctuation
    BenjaminS
    Powered by Imagination
    http://www.ccarproject.net/
    Apr 2005
    My steering wheel has volume up/down, mute, and another button..
    I'm planning on using a Griffin PowerMate for volume and pause, then using the steering wheel controls for next/previous track, and hopefully roll in some bluetooth cell phone integration..
    The plan is probably to use a hacked up usb num pad to interface with the steering wheel controls.. that way no drivers or special software would need to be written..
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Would an iPac work? It's a USB keyboard emulator, right? If you can get your steering wheel controls to connect to the iPac, the Mini Mac ought to see the iPac as a keyboard, right?
    As long as there are key shortcuts for the application, I'd think you'd be golden.
    Want to:
    Apr 2005
    Well, the I-Pac definitely has potential.. but I'm not sure how well it would work with iTunes, all of the keyboard commands appear to include a complementing Command keystroke, so it might not work at all. Plus, all of us lightweights that couldn't hook servos up to our screen, and reroute our vents, probably couldn't wire a board up to our car.. haha, props for your install.. it's very clean and comprehensive.
    I bought the Griffin PowerMate, this thing is great.. it automatically switches profiles for each application that it recognizes, and you can customize everything. The LEDs in the base change brightness with the volume level..
    Default operation in iTunes is as follows:
    Spin left/right = volume down/up
    Click = play/pause
    Click and hold = eject optical drive
    Click and spin left/right = previous / next track
    I'm still playing with it, but it seems to have the ability to provide a lot of features in a small package.
  1. Mac Mini MINI
    By FireAnt in forum MacCar
    Last Post: 07-30-2008, 07:06 PM
  2. Replies: 7
    Last Post: 07-02-2005, 04:47 PM
  3. Powering a Mac Mini Carputer
    By shizzle in forum Power Supplies
    Last Post: 03-14-2005, 02:38 PM
  4. Wireless control for steering wheel
    By DodgeCummins in forum General MP3Car Discussion
    Last Post: 02-15-2002, 02:14 PM
