Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 80
Thread: Some progress on the application...
  1. #21
    Feb 2005
    None i know of
    Quote Originally Posted by Jirka Jirout
    Is there some documented API or is the Radioshark software scriptable? I do not have this tuner and do not plan to buy one, because of the lack of RDS support and dubious quality of reception. However I can try to make a skeleton of a module, but someone would have to fill in the code that actually interfaces with Radioshark hardware.
    Hi Jirka
    No API as far as I know. Guess some of it is scriptable based on the widget they have for it.
    I mean NO disrespect but I would be willing to put up some $$ to get you one. I'm sure a few others might like to chip in too ?
    If not, I will send you my unit or let me know cost from apple store closest to you (shipping will be free and u will prob have it in a day) :-)
    Btw. I am entitled to a edu discount....but not overseas I think..
    Let us know (either via here of PM) if this makes sense, is ok, or it will not fly ....
    thanks again
  2. #22
    May 2005
    Munich, Germany
    Quote Originally Posted by jdkarr01
    I'm still trying to get this running but even with your binary I only get it to come up with the screen but no modules load. I can use the key commands you gave but each module location is blank. What am I doing wrong.
    Same here... *sigh*
  3. #23
    Jul 2005
    all I really did for touch screen is made invisible buttons over the moduals, then I had the buttons go to the activated view. I wasn't extreemly far on it because there isn't alot to do without the hardware, but maby some more progress can be made with this new version.
    PS. can you post a list of all the hardware you are currently using and where you bought it or how u made it?
    Also can you post a compiled version so I dont have to build all the moduals to start playing around with it? I built them all but the internet moduals won't work at all.
  4. #24
    Jan 2005
    Fairfield County, CT
    yea same. Tried building from source and running the binary as-is on 10.3.9 and 10.4.2, nothin.
  5. #25
    Jul 2005
    this happened to me as well untill i placed moudals in the folder 1 at a time. I found the problem was with systemmenu just run it without it and it will work fine but I still cant get the internet stuff to work
  6. #26
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    Yes, there is a bug in the System menu. It does not properly create its default setup dictionary - easy to fix - have a look at the contents of dictionary moduleSetup in the initWithSetup and then at what is expected to be there in -setupReadSettings ;-)
    Fixed Sysmenu.m file is attached.
    Attached Files Attached Files
  7. #27
    Jul 2005
    Netherlands
    Quote Originally Posted by raceer
    OK, I downloaded the software for RadioShark and looked at it. It is definitely not scriptable. BUT - it is written in Cocoa and should therefore be quite easy to hack. I just need to find a way of smuggling a bundle/plug-in into it.
    The unit or the price are not a problem. If you think the RadioShark is good enough for in-car use, I can grab one from AppleStore in London when I am over there and try to make a module for it.
  8. #28
    Feb 2005
    umm could you guide me through compiling it with xcode?
    ive never used it before
    i try to open the mainapp folder in xcode i get this error:
    Couldn't open /Users/simon/Desktop/car mp3 stuff/TatraApp-2005-07-24/MainApp/TatraApp.xcode.
    Reason: *** -[PBXToolbar _notificationPostingEnabled]: selector not recognized [self = 0x41ba990].
  9. #29
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Sorry pal, this aint the place for that.
    Check
    developer.apple.com
    or
    apple.com/xcode
    If you havent worked in programming at all, this aint the place to ask questions of that nature. IF you need how to go from C++ to Xcode, I still say mp3car.com aint the place to start.
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
  10. #30
    Jul 2005
    that new file still wont fix it. I recompiled and same thing, all empty-slots but there is nothing in the title box that sais empty either. I then took toe modual out and it ran just fine. I still cant seem to get the internet stuff though.
  1. Neocar External Application Bug Fix!
    By reddeath30 in forum NeoCar Media Center
    Last Post: 04-07-2005, 09:25 AM
  2. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
  3. How to embbed any Application in RR ?
    Last Post: 03-20-2005, 01:35 PM
  4. Beta-Testing External Application Code
    By CarComp in forum Media Engine
    Last Post: 02-17-2005, 11:42 PM
  5. Cdplayer application
    By kreyzig in forum FrodoPlayer
    Last Post: 06-19-2004, 11:51 PM
