Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: MacMini
  1. #11
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    YES, why do you want/neeed optical, im curious?
    (All done)
    iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
  2. #12
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    I guess she wants optical to some sort of $1,000,000,000,000,000 audio setup she uses as she is loaded
  3. #13
    Feb 2005
    just use a soundblaster audigy NX2 (usb connection) ... your Mac Mini will recognise it as a audio device, you can use the optical output from that but you can tweak the sound settings from the Mac OS since there are no support software on Mac.
    Once you have the optical out, pipe it to something like the Alpine H701 ... and you're pretty much in business.
    that's my next upgrade... firewave does not have optical out ....
  4. #14
    Mar 2004
    Bristol
    but a soundblaster is just not cool enough for a mac user! for a start it's not white or translucent!
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by sdashiki
    an optic cable won't let noise into the system. all other forms will.
    it's a MUCH cleaner signal.
    Jan Bennett
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Piperclub
    this is an option, however, there will be no messing with the settings on the computer for the reason you stated below.....all of that will be done on the H701, i fyou start messing with too many adjustments in too many different places you can mess a lot of things up...lol
    Jan Bennett
  1. MacMini bad USB no power
    By FireAnt in forum MacCar
    Last Post: 04-01-2005, 08:04 AM
  2. Rayming TripNav GPS?
    Last Post: 03-29-2005, 04:32 PM
  3. MacMini CarPuter
    By LekanB in forum General Hardware Discussion
    Last Post: 02-26-2005, 01:30 PM
