Results 1 to 10 of 15
Thread: OBD-II Mac interface?
    Jul 2005
    Hi, i'm aiming to upgrade my car with my 2006 Tax return, and i'm starting to weigh my options. I'm trying to decide between a Pioneer Avic N2 and setting up a Mac Carputer. I know that the Avic does not have a OBD-II interface, and i've read that a mac can use a couple of the PC versions while emulating.
    Is there any OBD-II interface or software that works natively with a Mac?
    Would a simple gadget like this
    http://www.thinkgeek.com/gadgets/electronic/72fc/
    work better just to beable to see the data?
    Sep 2005
    i have freediag working on osx
    freediag can be found here: freediag.sf.net
    i'm not sure if the current CVS source will work on osx. but i have a version that another guy and i got working. if you would like the source let me know.
    to connect the computer to OBDII i used the BR-3 which you can find here:
    http://obddiagnostics.com
    this was then connected using a keyspan serial to usb connector.
    cool stuff!
    Newbie anthropod's Avatar
    Mar 2005
    Southeast, NC
    I am not a programer, but looking at the widget programming guide, could you not make a widget that called the freediag command line and returned a value so you could have a GUI?
    7" Lilliput
    1.42 Mac mini (512MB,80GB,Combo,Bluetooth,Airport)
    Carnetix P1900 with CNX-P5V
    Radioshark
    GPS (BU-303)
    Polk MMC 650
    Infinity Kappa 62.7i
    Alpine MRP-F240
    Sep 2005
    unfortunatly no you could not. freediag has it own cli. it displays all the data in a kind of table like format within the shell. i did start to work on a cocoa interface but didnt get to far because of other projects. the freediag program is written in c so an gui interface can be written for it.
    Jul 2005
    Can you post your version that runs in osx? I can't find it online anywhere
    Sep 2005
    sure here is the source code. it is in xcode 2.1 but should compile without it.
    Sep 2005
    i started doing some testing with that code and it does not work on tiger. i haven't used it since panther.
    there is a problem with the serial connection code in diag_l0_br.c
    i will try and work on it and post the changes when i get it working.
    Jul 2009
    just wondering if one of you guys could please upload the source code again or something (if you still have it),
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Check the OBDII forum. You are looking for obd2gpslogger by Chunkyks. There's a forum for it. Runs in OSX.
    Want to:
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Also it's in my sig :-D
    Actually, this reminds me that I need to do an OSX build. If you give it a couple hours, I'll put up an OSX app bundle for download; I tagged a new version of the software yesterday.
    [Or, if you're a developer and can build and install stuff yourself, feel free to grab the source and go to town].
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  3. my OBD II Software
    By kocke in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-06-2005, 03:53 PM
  4. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 01:25 PM
  5. OBD II Interface (BR3) UK Cheap!
    By benje in forum Classified Archive
    Last Post: 09-05-2004, 07:55 AM
