Results 1 to 8 of 8
Thread: Mac Mini HD & Driving, bouncing etc....
    Oct 2005
    Huntington Beach CA
    Unhappy Mac Mini HD & Driving, bouncing etc....
    I am wirting to see if anyone else has had this problem? I was told AFTER I installed this amazing system that the reason my HD crashed was bc it while driving and bumps and etc..caused it to mess up. Well I wanna how true this and also AM I domed to have this problem often, or was it just a BAD mac mini. It continues to give me the grey screen, where tells you to shut down bc of error...
    HELP SOMEONE
    http://www.macvroom.com/node/69
    Elsewhere
    Search the Power Supplies forum. There's much discussion of hard drives there, with other peoples' experiences. It may or may not be of help, but it will give you some insight to a long-runnign debate.
    How about the Wiki?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I can't imagine that the Silverado is harsher than the Mini or some of the other cars with Mini's in them. I haven't had any problem with mine and haven't heard of any other crashes. The Mini has a laptop drive inside and they tend to handle abuse pretty well.
    I think you may have gotten a bad drive.
    Want to:
    Low Bitrate FireAnt's Avatar
    May 2004
    Houston, Texas
    Mine has sort of skipped during song playback before. But nothing too serious. A couple of my songs have had to be reloaded after developing problems. Mine gets hammered! I was driving on 18" wheels and 35 series tires until my tires had no tread left. This is on a MINI Cooper. With 15 inch wheels the ride is way smoother. I also had some skipping during heavy acceleration (Burn out launches and catching a 2nd). Overall I'm pleased with the performance. I would like to get a backup external hard drive to work with in the house and then quickly transfer it all to the Mac Mini when needed.
    Mike
    05 MINI Cooper Cabrio "Mac MINI"
    progress 95%- Mac Mini, Lilliput 7" , usb-wifi, Rayming GPS, Route 66,easy cat touch pad, CCAR front end"skinned",P1900 power supply
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    if your HD skips at all you have something wrong with your install or hardware.
    Check for loose connections or poorly mounted hardware.
    TruckinMP3
    Read the FAQ!
    Newbie CONSUMR's Avatar
    Sep 2005
    USA
    Experienced the same thing
    I was getting the same grey screen crash before I Hard wired the mac mini to the p1900. I thought it was crashing from overheating, but since I wired it to the p1900, I haven't had any problems.
    Feb 2005
    set your iTunes buffer to Large... it'll use more memory, but it'll reduce disk related problems....(i hope!)
    Feb 2005
    To say the least, mine gets hammered as well. I drive a 350z w/ eibach suspension and 19" wheels. An allready harsh sports car has been made even harsher. I am yet to have a problem, have had a little hard drive lag every once and a while. What I really worry about is the heat and its effect on the CPU internals. I live in atlanta. Needless to say it gets HOT down here.
  1. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 05:25 PM
  2. Mac mini in dash questions.
    By dfluxnet in forum MacCar
    Last Post: 10-03-2006, 04:02 AM
  3. Mac mini in my 2006 Honda Ridgeline
    By coolcat in forum Show off your project
    Last Post: 04-23-2006, 02:11 PM
  4. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 01:25 PM
