Originally Posted by
4thChild
Below are before and after shots of the monitor placement options. I would really like a clean monitor install and the Xenarc almost fits perfectly. The bottom 1/4 of the monitor is to large to fit exactly which means I would need to cut the double din at the base of the install. Or I may place the monitor behind the plastic double din trim. Placing the monitor behind would recess the monitor about 3/4 to 1 inch and Im not sure how that would look.
Another option is to have it sit as in the picture with an arm that would swing and allow me to access the DVD slot on the mini with out jumping through hoops.
What do you experts think??
