Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Mac mini (iLex) shuts down, all the way down
  1. #11
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Post this in the Carnetix forums and Mike will help you out.
    Other suggestion I have is to disconnect the power to the P1900 and then reconnect. Perhaps it just needs resetting. Glad the Mac is okay.
    Did you check to make sure that the Energy Saver-->Options panel has "Allow power button to sleep computer" checked?
    I also note there is an option to restart the computer in the case of a power failure. I suppose it's possible that the P1900 is starting the computer, then overloading and shutting down, then the restarting and the Mac restarts after the power failure.
    BTW - Harmony is my app and it doesn't quite properly from the menu. You have to select it from the dock to make it quit. But I've never had it scramble the system because of that.
    Want to:
  2. #12
    Newbie minicoopS007's Avatar
    Sep 2005
    Gaithersburg
    Wink
    Hi bugbyte, I don't think harmony or iKarr were the culprits, in fact I'm modifying both apps as i write this. The Mac is working fine. I believe p1900 is the cause, just have to figure out how to reset it. I will look into the power settings. Thanks for your input, i should have stopped by your office and pinged you on this matter.
    cheers
  3. #13
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Aah! You changed your screen name!
    You should have dropped by. I'd rather talk Macs than do work.
    Want to:
  4. #14
    Constant Bitrate MacMobile's Avatar
    Sep 2005
    Trois-Rivieres, Qc, Canada
    Quote Originally Posted by minicoopS007
    The mac goes into sleep mode when the car is on. The mac will boot up, then shut down. Then turn the car off the mac will boot up then shut down.
    I had a similar problem once. The Fan inside the P1900 had been disconnected and it is one of the cause that make the P1900 cut power. Every time I would start or turn off the car, the Mac would start-up, stay on 1 minute since the command is lock 1 min, then it would shut down.
    I do not remember it if was a graceful shutdown (signal send by P1900 to shutdown) or just power being cut. In your explication I could not see which one you had either.
    There are 2 LEDs inside the P1900 and, in the manual, there are many errors code listed. It will give some troubleshooting information. I know that is strange that a electrical problem would occur at the same time that you installed new software but since it is working well when not powered by P1900, you have to look more around the P1900.
    Hope this help.
    Franco
    Help me keep my web site up to date.
    Mac-Mini in Passat
  1. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 10:16 PM
  2. Mac mini in dash questions.
    By dfluxnet in forum MacCar
    Last Post: 10-03-2006, 03:02 AM
  3. First Mac Mini in a Land Rover
    By dmonckton in forum Show off your project
    Last Post: 08-14-2005, 06:53 PM
  4. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 12:25 PM
