Results 1 to 10 of 10
Thread: removing very top menu bar
    Apr 2005
    I have been googling but i cannt find an answer.
    does anybody here know how to remove the top menu bar as its messing up my full screen flash app.
    thanks.
    Feb 2005
    few minor issues but this is a great lil util and also does the job
    http://www.macupdate.com/info.php/id/16640
    YMMV
    __________
    rgds, raceer
    Constant Bitrate TheLandYacht's Avatar
    Oct 2005
    Austin, TX
    Quote Originally Posted by raceer
    But...but...but...that's MAC!!!!!!!!!!!!!!
    By the same token, I'll reiterate. The menu bar I (and maybe he too) would like to get rid of is the one with the minus/minimize/maximize/x-close in the top right corner. He ain't the only one who would like to get rid of it.
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by TheLandYacht
    Isn't that a property you can change in IB? (cant remember if it is an option for the Window or a different window style).
    EDIT: Hmmmm.... Don't see it on a quick glance in IB under Panther. I could swear I saw it some where though....
    -dave
    Apr 2005
    raceer has the right idea, but it seems that that programme just darkens it.
    There has to be a way to remove it or overlay a flash projector over it.
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    To remove the menu, simply use this:
    [NSMenu setMenuBarVisible:NO];
    Oct 2005
    Austin, TX
    Quote Originally Posted by Jirka Jirout
    And where would I put that? registry (where)? other?
    Jul 2005
    Netherlands
    Ehm, sorry, I overlooked you want a solution for Flash. ("Flash application" is kind of oxymoron to me).
    This is what you would use in a Cocoa application. Typically you would want to execute this code as soon as your application has started. For example in response to -applicationDidFinishLaunching: message, sent to the NSApp's delegate or when you create the main window (you have to create a borderless fullscreen window programmatically anyway).
    If you insist on Flash, you can create a simple Cocoa wrapper with fullscreen window, use a WebView as its content view and display your flash application within that view.
    BTW: Mac OS X has no "registry"...
    Apr 2005
    I am only using flash as its all I know how to write in.
    I will have a look at Cocoa. if its similar maybe it could port my app over to it.
    Well, just gone and had a look at it, and bugger that, I'm sticking to flash!
    Apr 2005
    After all that there is a very simple solution.
    the web browser Opera offers a full screen mode, and it hides the top menu bar perfectly.
  1. Moving the menu to the top
    By MatrixPC in forum MM Skins
    Last Post: 05-16-2005, 05:16 AM
  2. removing one bar and making another bigger
    By Dave_Perth in forum Map Monkey
    Last Post: 04-19-2005, 02:57 AM
  3. Replies: 2
    Last Post: 02-15-2005, 07:31 PM
  4. Menu always on top, other new features
    By clean customs in forum FrodoPlayer
    Last Post: 01-22-2005, 05:27 PM
  5. Frontend 1.1.2 - Info Bar Up Top
    By Headsex in forum Map Monkey
    Last Post: 11-29-2004, 04:50 PM
