Results 1 to 8 of 8
Thread: Adding external wifi antenna to ibook
    Nov 2005
    Sonoma County, CA
    I am getting a new ibook with built-in wifi and bluetooth for my in-car computing. I want to be able to use either a rooftop antenna or a cantenna at times when I am driving long distance. I can use my cell phone for internet access, but there are times when I would also want to use an antenna.
    The problem is that the ibook does not have a card slot, so I can't make a direct connection to the antenna. I am wondering if I can connect the antenna to a powered access point or router inside the car such that the ibook picks up the stronger signal? Would the Apple Airport work for this?
    I have done an extensive search on the site, but I can't find anything addressing this connectivity issue.
    Any ideas?
    Thanks!
    Maximum Bitrate churnopol's Avatar
    Apr 2003
    Delaware!!!
    well i have my ibook in my lap right now. you may have to drill a hole in the case for the antenna cable
    here's some apple antennas that fit the ibooks wireless airport card
    http://store.yahoo.com/lovemacs/9224560.html
    http://store.yahoo.com/lovemacs/9226043.html
    http://store.yahoo.com/lovemacs/cp42.html
    Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
    Better than winamp. Click here for qcd player.
    Apr 2003
    Delaware!!!
    Apr 2003
    Delaware!!!
    ok how the hell did i post all those
    here's a usb airport for ibooks
    http://store.yahoo.com/lovemacs/wua400.html
    Variable Bitrate viper24's Avatar
    Oct 2005
    Sacramento, CA
    i have one of those smaller wireless antennas. $5 shipped...
    2005 Dodge Ram HEMI
    http://www.cardomain.com/ride/2239451
    15" LCD touchscreen
    Mac Mini
    6" Headrest monitors
    Modded Xbox
    5 PSone screens going in doors
    And another 15" LCD!
    Nov 2005
    Sonoma County, CA
    Thanks, but these don't quite address my problem, though you're idea of drilling a hole in the case to connect directly to the inbook airport card does. I thought of that, too, but I don't want to void my warranty.
    Some kind of access point/repeater/router is what I think I need. It will be connected to the external antenna and reradiate the signal to the ibook inside the car, just like a GPS reradiating antenna works.
    Constant Bitrate MacMobile's Avatar
    Sep 2005
    Trois-Rivieres, Qc, Canada
    QuickterTek has some antenna that can be install in PowerBook.
    You have to plug it inside the PowerBook and let the wire go out through the PC card slot.
    For the iBook, they have the antenna:
    http://www.quickertek.com/iBook_Antenna.php
    I did not check how to install it in the iBook.
    They also have the 27 dBm transceiver.
    An Airport base station has about 30 mw of power,
    the QuickerTek transceiver has around 500 mw.
    Franco
    Help me keep my web site up to date.
    Mac-Mini in Passat
    Nov 2005
    Sonoma County, CA
    I contacted Quickertek about their ibook transceiver. They are coming out soon with a new model that works with the built-in wireless of the new ibooks. An external antenna can also be attached. This will solve my problem.
  1. Replies: 9
    Last Post: 04-22-2006, 08:22 AM
  2. FS/FT Lucent Orinoco USB WiFi + External Antenna
    By ukchris in forum Classified Archive
    Last Post: 10-12-2005, 04:37 PM
  3. USB wifi with external antenna?
    By Micke in forum Wireless Communications
    Last Post: 07-05-2005, 12:56 AM
  4. Replies: 11
    Last Post: 12-06-2004, 03:48 PM
  5. Gps Module + External Antenna + Waas + Usb
    By e_z_street in forum GPS
    Last Post: 10-06-2004, 03:57 PM
