Results 1 to 5 of 5
Thread: Problem with USB devices not working after restart
    Sep 2005
    Hi guys,
    I have a strange behaviour with my USB devices connected through a HUB that is powered by the P1900.
    I have my Touchscreen and Powermate on the USB Hub, but every so often after a restart or wake from sleep the touchscreen and / or Powermate isn't working until I take the plug out and put it back in...
    Any ideas on how to get this annoying problem solved?
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    I am experiencing what I believe is the same problem with the PowerMate from time to time. However, I do experience it even when the USB hub is only powered from the Mac mini. I first thought the problem was caused by a wrong cable or connector, but now I believe the problem is something (no idea what exactly) in the PowerMate driver.
    Could you check your log whether you can find something there? I can see "PowerMate device removed" message when the PowerMate stops responding and then "PowerMate device added" when I disconnect and connect it again. Strange thing is that even during the time PowerMate does not respond, it is visible in the Apple System Profiler.
    Constant Bitrate MacMobile's Avatar
    Sep 2005
    Trois-Rivieres, Qc, Canada
    I have the same problem. Here is my current config:
    Back off Mini
    ***TouchScreen
    ***USB cable to first hub
    First hub
    ***iMic
    ***USB cable to 2nd hub
    Second Hub
    ***radioSHARK
    ***PowerMate
    ***BU-353 GPS
    I have tried many configurations and for a while I had problem with readioSHARK but sometime with others. With this configuration, it is the PowerMate that fail most of the time at wake-up. I look around in google and I found that there is a known bug in Window XP with some devices after waking up from sleep. I wonder if Mac OS X does have the same problems.
    Help me keep my web site up to date.
    Mac-Mini in Passat
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I have my Powermate attached through a non powered hub and haven't had this issue.
    Want to:
    Sep 2005
    Quote Originally Posted by Bugbyte
    All my hub are powered ones, I will try to keep only the USB plugged in to see if the problem disappear.
    Thank you
    Mac-Mini in Passat
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  2. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 12:07 PM
  3. Found 5V@10A PSU to power USB hubs, devices, etc
    By moahdib in forum Power Supplies
    Last Post: 08-21-2005, 12:53 PM
  4. usb hub power problem
    By modUlarBeing in forum Power Supplies
    Last Post: 11-21-2004, 06:34 PM
  5. USB Devices, and Hibernation / Suspend to RAM
    By t0ffluss in forum General Hardware Discussion
    Last Post: 01-06-2003, 08:40 AM
