Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 53
Thread: Google Earth for OSX
  1. #11
    Variable Bitrate viper24's Avatar
    Oct 2005
    Sacramento, CA
    has anyone gotten the gps reading program to record files that GE can read yet? It seems easy. If we get this working we will have a nice mp3car.com homebrew GPS program. and with Dash_Run, we might be able to finally get something good goin here!
    2005 Dodge Ram HEMI
    http://www.cardomain.com/ride/2239451
    15" LCD touchscreen
    Mac Mini
    6" Headrest monitors
    Modded Xbox
    5 PSone screens going in doors
    And another 15" LCD!
  2. #12
    Constant Bitrate zapwizard's Avatar
    Aug 2002
    Austin, TX
    I found a "cache proxy" program:
    http://tlog.dehumanizer.com/2005/09/...th-with-squid/
    What it does it run like a proxy and cache all data that you request. (can can do google earth)
    So in theory you can go beyond the 2000MB cache on GE.
  3. #13
    Low Bitrate SurgResDocMD's Avatar
    Dec 2005
    The Damn Hospital
    zapwizard what file do I download, those are all exe. files?
  4. #14
    Aug 2002
    Austin, TX
    It looks like it has to be built from the sourcecode.
    I don't have my USB puck yet so I haven't actualy tried it out yet.
  5. #15
    Newbie qkslvr's Avatar
    Feb 2005
    Wheaton, IL
    How can we adjust the "Fly to" settings so it does not zoom out/pan so high/fast when going from one point to another that are far apart?
    Pictures never lie.
    Only Photoshop does.
  6. #16
    Aug 2002
    Austin, TX
    It depends on what you are trying to do.
    Tools -> Options -> Control -> Advanced
    But if you want it to actual follow the path and do a "birds eye view", select just the "ROUTE" item and press PLAY.
    Otherwise it just zooms out and back in, rather then following the path.
  7. #17
    Aug 2002
    Austin, TX
    Ok, so I got my GPS puck yesterday.
    Downloaded GPSbable for OSX.
    -It is very hard to find the compiled version, goto downloads, press the + next to version 1.2.5, and then click on MacGPSBabel-1.2.5.zip.
    In either case version 1.2.5 for OSX only supports Garmin and Magellian GPS units.
    So back to my earlier posts, does anyone want to write a script or small app to bridge NMEA data to KML?
  8. #18
    Jan 2006
    I'm guessing it will go like this.
    1) get a basic gps program that just spits out the nmea data to a file every few seconds.
    2) have an applescript read this file and create a kml file
    3) have google earth read this kml file.
    problems and/or tough spots:
    -how to get the kml file to refresh
    -is google eath scriptable...i'm guessing it is, but how much?
    -can it be told to read kml files?
    I'd love to help out, but I don't have a gps mouse to test it out on.
    What program would you use for #1?
  9. #19
    Jan 2006
    This solves #1:
    http://www.cs.sunysb.edu/~tony/392/G...dDirector.html
    Now if someone would check the scriptability of google earth we'd be all set (I can't right now as I am at work)
    EDIT: gpsy cost about $50 ($30 student) and provides some mapping capabilities itself. I'll bet there is a free version of something that reads the nmea data and either outputs it to the console or a file...either is good enough.
    This also solves #1
    http://www.macsimplegps.com/ but it doesn't help those who don't have a brand name receiver.
  10. #20
    Aug 2002
    Austin, TX
    As long as I can pull all the data I need out of that it looks like it should work.
    Otherwise I found this:
    http://mysite.verizon.net/vzenuoqe/MacSoft.html
    But it would require a lot more decoding.
    Here is what I have figured out is needed for live KML tracking:
    From NMEA:
    -Latitude
    -Longitude
    -Altitude (optional)
    -Speed (optional)
    -Course
    This website has info on the NMEA sentence structure:
    http://www.commlinx.com.au/NMEA_sentences.htm
    Minumum required for KML file:
    -Latitude
    -Longitude
    -Heading
    Optional:
    -Range (Zoom based on current speed)
    -Altitude
    The minimum KML file is:
    Code:
    <?xml version="1.0" encoding="UTF-8"?>
    <kml xmlns="http://earth.google.com/kml/2.0">
    <Placemark>
    <name></name>
      <LookAt>
        <longitude>-97.815522808536</longitude>
        <latitude>32.88081563386183</latitude>
        <range>480.34159687574</range>
        <tilt>60</tilt>
        <heading>180</heading>
      </LookAt>
     </Placemark>
    </kml>
    Add this code for a tracker:
    Code:
     <Style>
        <IconStyle>
          <Icon>
            <href>root://icons/palette-4.png</href>
            <x>32</x>
            <y>128</y>
            <w>32</w>
            <h>32</h>
          </Icon>
        </IconStyle>
      </Style>
        <Point>
        <coordinates>-97.815522808536,32.88081563386183,0</coordinates>
        </Point>
  1. Embedding Google Earth to RR
    By Asskick in forum Road Runner
    Last Post: 02-10-2006, 10:44 AM
  2. Embedding Google Earth
    By 106-Quiksilver in forum GPS
    Last Post: 12-06-2005, 01:03 PM
  3. Google Earth and GPS
    By timdastis in forum GPS
    Last Post: 09-15-2005, 09:23 AM
  4. Google Earth
    By liquid_smoke in forum GPS
    Last Post: 07-10-2005, 10:53 PM
  5. google earth
    By Ascension in forum Software & Software Development
    Last Post: 06-30-2005, 06:35 AM
