Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 53
Thread: Google Earth for OSX
  1. #21
    Jan 2006
    http://www.chimoosoft.com/gpsconnect.html
    You might be able to read the nmea data off your gps unit with this.
  2. #22
    Jan 2006
    yeah ^^
    There is applescript stuff for reading xml formats as someone pointed out (imgnat maybe) earlier.
    I might get a look at all this stuff this weekend and see how feasible it really is.
  3. #23
    Constant Bitrate zapwizard's Avatar
    Aug 2002
    Austin, TX
    I already am running GPS connect on my mini.
    It reads data just fine, but has no live export feature.
    It also doesn't log NMEA data, it's more for import and export of waypoints.
    Here is a utility that can generate XML in applescript.
    http://www.latenightsw.com/freeware/XMLTools2/
    It may or may not be needed.
  4. #24
    Jan 2006
    to be honest I think that sometimes creating xml is made more complicated than it really should be.
    At work I've found that if the xml is not very nested and is a smaller file straight coding it can be easier than using a object model or specific xml API. Since this is a small file that will be fed constantly to another program speed is of the essence...the solution may be to write it as plain text.
  5. #25
    Aug 2002
    Austin, TX
    I agree, I am going to simply try to use the Apple text editor to generate the KML, and just feed it the right data to the right feilds.
    Also this program supports Applescript.
    http://www.gpsnavx.com/help/applescript.htm
    I have the demo on the mini, I wonder if it also is applescript ready.
    My basic layout for the script will be:
    -Get required NMEA data from application
    -Is speed greater then zero?
    -If so, pass values to text editor
    In theory you can make both a live tracker, and provide all the relivant GPS data in a HTML pop-up or overlay.
  6. #26
    Jan 2006
    I looked a bit at google earth. It doesn't look very scriptable at all. I think it might be better to use another, lower level language to do this.
  7. #27
    Aug 2002
    Austin, TX
    You don't have to actually pass anything into google earth via AppleScript.
    Just make a network linked KML file, it shouldn't be any harder then collecting the info and putting it into the proper place in the KML file.
  8. #28
    Jan 2006
    oh, cool
  9. #29
    Aug 2002
    Austin, TX
    Ok, the only shareware GPS program that seem applescript friendly is Terraserver.
    But I haven't messed with it yet.
    I don't want to pay $50 for a program that "might" work.
  10. #30
    Low Bitrate SurgResDocMD's Avatar
    Dec 2005
    The Damn Hospital
    Quote Originally Posted by zapwizard
    Let's all chip in paypal style! $5 a piece to get this going0l33l
  1. Embedding Google Earth to RR
    By Asskick in forum Road Runner
    Last Post: 02-10-2006, 10:44 AM
  2. Embedding Google Earth
    By 106-Quiksilver in forum GPS
    Last Post: 12-06-2005, 01:03 PM
  3. Google Earth and GPS
    By timdastis in forum GPS
    Last Post: 09-15-2005, 09:23 AM
  4. Google Earth
    By liquid_smoke in forum GPS
    Last Post: 07-10-2005, 10:53 PM
  5. google earth
    By Ascension in forum Software & Software Development
    Last Post: 06-30-2005, 06:35 AM
