Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 83
Thread: 800 X 480 on Mac Mini with Lilliput 7" touchscreen
  1. #21
    Dec 2005
    Actually ignore the above - everything seems to have stabilised now and there is no more flickering.
    But does anyone know how to keep the 800 x 480 as the default res - my Mac defaults to a much higher resolution upon reboot and I can't get it to default to the 800 x 480.
  2. #22
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    I only had problems with keeping the default resolution when I was using the settings I found here and there on the internet. When I took time and created my own settings, all problems went away. Will try to post them, so you can give it a try.
  3. #23
    Dec 2005
    Thanks Jirka - that would be much appreciated.
    I looked into the cscreen option but it looks like the instructions on MacVroom are slightly incorrect because I can't get the directories set up correctly when following their instructions.
    Seems incredible that there is not a simple way to change the default setting to a low resolution. I read that a number of tests for appropriateness of the setting are done on startup and if any of the test fail a "safe" default is chosen instead.
  4. #24
    Dec 2005
    Bump!
    Jirka - any chance you could let me know those settings? It would be much appreciated.
  5. #25
    Jul 2005
    Netherlands
    Sorry for the delay, here you go:
    The thing is naturally set as Timing...
    Horizontal:
    - Active: 800
    - Front porch: 32
    - Sync: 56
    - Back porch: 136
    Vertical:
    - Active: 480
    - Front porch: 2
    - Sync: 3
    - Back porch: 92
    Refresh rate: 60.015 Hz
    If this does not work for you, just go to the DisplayConfigX page, read the basics of how it works and experiment. And you may need to adjust the image position using the display's on-screen menu. In case you have two Macs, enable the ssh login on the one te screen is connected to - in case of problems, you can go in using ssh and delete the files generated by DisplayConfigX - much easier than having to go to single user mode etc.
  6. #26
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thread name changed to make it easier to find with a search.
    Want to:
  7. #27
    Dec 2005
    That's great thanks Jirka.
    I've made the adjustments but I am thinking that I need to set the first page also as the DisplayConfigX notes say that these must be correct.
    I've searched all over the net for these specs but they really don't seem to be anywhere.
    Can you tell me what you used on the first page (Monitor)?
  8. #28
    Jan 2007
    I have had no luck getting 800x480 on my lilli eby701 and intel mac mini core duo. I hope your settings will work for me Jirka.
  9. #29
    Dec 2005
    CaptainTrap - I think it is important to get the "Monitor" page setting correct also. Unfortunately there seems to be no information out there on what the Lilliputs specs are.
    We are going to be reliant on Jirka or someone else who has successfully implemented the lower resolution telling us what they entered for the first page.
  10. #30
    Oct 2006
    post #15
    i said i had the same problems at first. then i changed the default refresh rate to 60hz and didn't have the out of range issue.
  1. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 04:25 PM
  2. Replies: 2
    Last Post: 10-01-2006, 07:23 PM
  3. Mac Mini in a Mazda Protege
    By zapwizard in forum Show off your project
    Last Post: 08-07-2006, 08:18 AM
  4. Replies: 6
    Last Post: 09-25-2005, 10:51 AM
  5. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 12:25 PM
