Please let me know if you figure this out. I am searching and searching for the answer! I have found some tips on getting the Xenarc screen to work using DisplayConfigX. However, so far I have not been able to use the same specs for my 7" Lilliput.
Hi I am new here I don't know if this is the right thread to ask this question. Is it possible to have 800x480 resolution on a 7" lilliput with the mac mini? If this is possible hope somebody could help me thanks
try these settings
800 active 480
24 front porch 3
72 sync 7
96 back porch 10
bandwidth 29.910
horizontal frequency 30.151
refresh rate 60.302
must be a timing resolution
i think those are the settings i used. i'll check to make sure
let me know if you have questions
Where is it located? thanksOriginally Posted by onepuff
it is in the resolutions tab
go to that and click on the + symbol
enter the settings and then you need to install it
the displayconfig x website can answer some questions
http://www.3dexpress.de/
Yup this will do it. Did it this weekend. Gluck.Originally Posted by onepuff
Worked for me too! Thanks guys. Its almost done now.
thanks one puff.... worked like a charm...
i have a lilliput eby701. when i enter the resolutions tab and hit + displayconfigx will not give me an option to change the front and back porch along with the sync. does this mean my monitor wont support 800x480?
