Results 1 to 5 of 5
Thread: Disable USB in software? (Keeping the Mini Asleep)
    Constant Bitrate zapwizard's Avatar
    Aug 2002
    Austin, TX
    My mini wakes from sleep on the slightest move of the mouse, sometimes only seconds after going to sleep.
    Without using a P1900, does anyone know of a way to disable the Wake from USB function on a Mac Mini?
    I don't want to have to manualy turn off my hub everytime I put the mini to sleep.
    It seems like there could be a script that could disable or unmount all the USB devices on sleep, and then remount them after waking up.
    Jul 2005
    in sys prefs under keyboard and mouse you can change the tracking I believe this is basicly the sensitivity so if you don't mind making it a little slower that could be an option
    atl
    atl is offline
    Newbie atl's Avatar
    Nov 2005
    Germany
    There is an option on the Carnetix P1900, which cuts the secondary power before the primary one. If you power the USB hub from the secondary power on the P1900, it should lose the power before the Mac mini goes to sleep.
    But it need to use a hub, which works only with external power.
    ByE...
    Aug 2002
    Austin, TX
    Bcohen5055, that doesn't change the wake up properties.
    atl, thanks but I knew that (said anything besides P1900)
    I didn't have enough time to order one before my trip.
    I have found an ok solution, use Hibernate mode.
    The mini won't wake from it on USB activity, and it boots up fast enough.
    atl
    atl is offline
    Newbie atl's Avatar
    Nov 2005
    Germany
    Quote Originally Posted by zapwizard
    Ooohps, next time I should read more thoroughly. Sorry.
    That's also a solution. But my Mac mini has problems with some USB devices. He won't wakeup correctly from SafeSleep. But if it's work for you, it's okay.
    ByE...
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Mini sleep questions - does yours do this?
    By Bugbyte in forum MacCar
    Last Post: 02-09-2006, 12:03 AM
  3. is the mini itx mainboard usb 2 m10000
    By g1smo in forum General Hardware Discussion
    Last Post: 10-03-2005, 12:59 PM
  4. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
  5. USB 2.0 vs. Firewire... keeping a low profile
    By gregulator in forum General Hardware Discussion
    Last Post: 12-11-2003, 08:08 AM
