Results 1 to 5 of 5
Thread: Having trouble getting Tiger on a Lombard PowerBook
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    Question Having trouble getting Tiger on a Lombard PowerBook
    I got a G3 powerbook 320mb mem 5gb hard disk
    - I know tiger will run on it - but - My unit has no firewire-
    no DVD drive - So I thought - I will use disk utility to clone
    the drive on a G3 desktop - buy taking the laptops drive out and
    putting it into a USB adapter - thats all I got on hand - I can
    get a laptop to desktop IDE hard disk adapter at work - I may
    have to use it
    - I tried to bless the drive with - TIGER2 is the USB drive -
    sudo bless -folder "/Volumes/TIGER2/System/Library/CoreServices" -bootinfo "/usr/standalone/ppc/bootx.bootinfo" -label "TIGER2" -setBoot -verbose
    and got it to boot a little - but it stops at a blank blue screen
    and looks like its trying to load something
    I am not that good at linux/bsd commandline stuff - and think
    my command is not right - any ideas
    I tried to reset the pram and all that -
    I gess, all there is left to do, is put the laptop drive on the
    IDE bus of the desktop and do a install
    Jul 2005
    for 10.00 apple will exchange your disks and give you a good set of CD-rom install disks, there might even be some on ebay so look around. But you first might want to check you have enough memory and all the other system requierments.
    Feb 2005
    Jefferson, AR U.S.A
    Quote Originally Posted by bcohen5055
    Its a unsuported model - only because it lacks firewire and DVD drive,
    some have upgraded to DVD drives and used a cardbus fireware card
    and got it to work on the same model as mine
    and there is a 400mhz with DVD and firewire - with the same
    motherboard but it has a DVD decoder chip
    so the hardware will work -
    I got it to boot to the desk top in safe mode
    and found out that
    sudo bless -folder /Volumes/TIGER2/System/Library/CoreServices -bootinfo /Volumes/TIGER2/usr/standalone/ppc/bootx.bootinfo
    should be enough to bless the USB drive
    now just got to do some google-ing
    Feb 2005
    Jefferson, AR U.S.A
    ok so far
    (1) I removed the PowerBook drive - and placed into a usb drive
    adapter - then pluged that into a Mac Desktop Running Tiger
    (2) I used Disk Utility to clone a OSX Tiger setup, because I cant
    install for lack of DVD or FireWire
    (3) I Blessed it using - on the computer I cloned it from -
    (4) Placed the drive back into the powerbook
    (5) Booted into "Safe Boot" by holding down "Shift" when you
    power on the PowerBook
    (6) Ran Disk Utility to check Hard Disk
    (7) Went to "/System/Library/Extensions" in finder - removed extensions
    for FireWire, Nvidia, and ATI Radion, AirPort, Printers, Joysticks
    (8) Used "OnyX 1.6.7" its Freeware, to clean system
    (9)System now boots - even if slow -
    Just got to optimize the system now
    Feb 2005
    Jefferson, AR U.S.A
    (10) Open finder, go to "/Library/Preferences" move the "Preferences"
    folder to the desktop, or were ever, - and reboot - if it boots faster
    just delete the folder "Preferences" if not I guess put it back,
    - left on its own, the "Preferences" folder will be re-created
    I now have a fast booting G3 PowerBook using OSX Tiger
  1. Navilock gps trouble!
    By damoru2 in forum GPS
    Last Post: 07-30-2007, 03:39 PM
  2. PowerBook Sleep
    By jtkellertx in forum MacCar
    Last Post: 07-13-2005, 12:58 PM
  3. Create an OBD Trouble Code?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-16-2005, 11:59 PM
  4. Replies: 5
    Last Post: 05-16-2005, 05:49 PM
  5. Tiger gone gold! Where to buy CHEAP?
    By kandyman676 in forum MacCar
    Last Post: 05-06-2005, 11:10 AM
