Results 1 to 8 of 8
Thread: Best way to convert DVI for a Xenarc 700IDT
    Jan 2006
    What is the most recommended way to go from DVI to the back of the Xenarc 700IDT. I have about 8-10 feet to travel with the video cable.
    Thanks in advance,
    Nomad
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by DiscoNomad
    Thanks in advance,
    Nomad
    There's a DVI to VGA adapter (should've came with the video card).
    Jan 2006
    Yes but what is the longest portion of the cable. In other words should I run the long length in a DVI to DVI cable and the put a converter on the end of that and then run a shorter VGA cable? I guess what I was asking was what is the "best" way to do it without losing signal.
    Thanks again,
    Nomad
    Elsewhere
    I don't think it matters much, really.
    It will be cheaper to have the DVI adapter at the PC and a longer VGA vable, sinve VGA cables are typically less expensive than DVI cables.
    How about the Wiki?
    Romania
    Quote Originally Posted by DarquePervert
    DVI cables are more expensive than VGA ones...
    Newbie agmsd's Avatar
    Oct 2005
    Talking
    I think the DVI is a much better option if you want to keep the quality at hightest... but if you're planning on a short distance I think both are approximatly the same. if you're planning to mount your pc in the trunk use DVi. I have two 19" LCDs at home one is connected with a DVI with a converter at the end and the other is connected with a D-Terminal drirectly to the screen with a converter plugged into the card. when I use more than 1.5m cable the quality decreases on the D-terminal... I think the same or may be worse will happen in the car with all the interference in a car's environment... Good luck...
    atl
    atl is offline
    Newbie atl's Avatar
    Nov 2005
    Germany
    Don't forget: The DVI port from the mini contains VGA (analog) and DVI (digital) signals within the DVI-I connector. With a DVI cable you will transport the analog signal about the length in the same way a VGA cable it will do. It makes no sense to use a DVI cable and put the adapter on the end. To get a much better signal you have to add a real converter to get the VGA signal direct from the digital signal. This will be much more expensive.
    For 8 - 10 feet you can use a good VGA cable.
    ByE...
    Sep 2005
    You are probably not going to notice that big of a difference in quality between the two in a 7 inch monitor anyway.
  1. Dont buy a Xenarc 700IDT!!!
    By cdcamaro9534 in forum LCD/Display
    Last Post: 04-12-2006, 04:29 PM
  2. Installing CD/DVD in Xenarc 700IDT
    By primusx1 in forum LCD/Display
    Last Post: 12-18-2005, 01:04 PM
  3. Voice nav on xenarc 700idt?
    By hotponyshoes in forum General Hardware Discussion
    Last Post: 11-08-2005, 02:03 AM
  4. Xenarc 700IDT is AMAZING!
    By spdyscotty in forum LCD/Display
    Last Post: 11-02-2005, 08:52 AM
  5. Yet another xenarc convert...
    By silencery in forum LCD/Display
    Last Post: 03-25-2005, 02:14 AM
