Results 1 to 6 of 6
Thread: 90* dvi to vga adapter
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    Does anyone make these?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yes. I found one when I was installing my Mini dock but I can't remember where it was. I ended up going a different route.
    Want to:
    Feb 2006
    NJ
    Well I've searched all over and can't find one...maybe I'll just have to make one like I saw someone do on here.
    Constant Bitrate zapwizard's Avatar
    Aug 2002
    Austin, TX
    I'm the guy who made one:
    http://www.flickr.com/photos/zapwiza...7594054134962/
    It wasn't hard, I took a ATI DVI to VGA adapter cut the plastic off (pretty easy)
    I did try to first bend it with heat, as the middle part is just soft plastic and wires, but in the end several wires broke off, so I just finished cutting it apart and re-wired it.
    I used the original Apple adapter and continuity meter as reference for wiring.
    I also just went out and ripped open the original apple adapter, inside it is similar, wires, encased in plastic, wrapped in copper foil.
    You could try to heat it and bend it, but make sure your bend doesn't stretch the wires, or you will be rewiring it also.
    Feb 2006
    CompUSA has them in the Mac section or you can order it here. It is not a 90 deg tho. It is a pigtail. There are some people posting comments about the device, but i sue one at home daily for my 15" AlBook and have been using it for nearly a year now with no probs. the key is to make sure that it is tightly screwed in on the both sides.
    http://store.apple.com/1-800-MY-APPL....1.0.9.1.1.0.1
    Dec 2005
    http://www.welovemacs.com/m8754ga.html ..i used this ..worked out great...
  1. AU Optronics Screen and VGA driver board (large images)
    By Maximus in forum The Review Palace
    Last Post: 11-27-2006, 10:16 AM
  2. Lilliput doesn't go into VGA mode anymore
    By thefreeauction in forum LCD/Display
    Last Post: 09-23-2005, 08:48 PM
  3. 8" Xenarc VGA Touch Screen LCD - $325 shipped
    By digitalww in forum Classified Archive
    Last Post: 09-08-2005, 10:15 PM
  4. VGA, usb adapter
    By vision in forum General Hardware Discussion
    Last Post: 06-09-2004, 04:10 PM
  5. VGA upgrade for TM-701L
    By digitalww in forum LCD/Display
    Last Post: 08-01-2003, 09:01 AM
