Results 1 to 10 of 16
Thread: NMEA extraction AppleScript need help
    Constant Bitrate zapwizard's Avatar
    Aug 2002
    Austin, TX
    I am trying to improve my GPS to Google Earth script.
    One way is to get rid of the GPSNavX program, and get the NMEA data off the serial port in the first place.
    I am just learning apple script and I have gotten far enough to see the actual data in the return window.
    Code:
    New Code below
    But I am having problems processing that data in order to extract the $GPRMC data. I may be going about this all wrong.
    SerialPortX is needed to interface AppleScript and the Serial Port.
    http://osaxen.com/files/serialportx1.0.html
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Question: if you build this into an application, does the user need to install the SerialPortX scripting addition, or will it be embedded in the executable?
    Want to:
    Aug 2002
    Austin, TX
    I have no idea
    I did fix my problem above
    Here is the new code though:
    Code:
    New code below
    Aug 2002
    Austin, TX
    Ok so I now have integrate a some-what working script with my other GPS to Google Earth script.
    But my GPS seems to spit out a LOT of crap data before spiting out the GPS data.
    The script runs once or twice in a row, but then craps out returning the giberish.
    Anyone want to try it out and see if it does the same on your GPS puck?
    Code:
    --WRITTEN by ZAPWIZARD
    --Requires GPSNavX and XML RPC
    --Find current Serial Ports
    property thePorts : {} --Attached Serial Ports
    --List the Serial Ports & select one from list
    set thePorts to serialport list
    set dev to choose from list thePorts
    --UnComment this, and insert your serial port name to diable the prompt menu.
    --set dev to "/dev/cu.usbserial"
    --Set your Time Zone Offset here
    set TimeZoneOffset to -6
    --Set Default Course direction
    set Old_Course to 0
    repeat
    	--Get data no more then twice a second
    	delay 0.5
    	--Open Serial Port
    	set portRef to serialport open dev bps rate 4800 data bits 8 parity 0 stop bits 1 handshake 0
    	--Check if available
    	if portRef is equal to -1 then
    		--Close port if program quit in error
    		serialport close portRef
    		serialport close 10
    		serialport close "/dev/cu.usbserial"
    		--Try again
    		--Display Dialog if still cannot open port.
    			display dialog "Could not open port "
    		end if
    	end if
    	--Que enough GPS data to capture valid data
    	repeat until (serialport bytes available of portRef) > 370
    	end repeat
    	--Read Buffered Data
    	set Buffer to serialport read portRef as text
    	--return Buffer --Uncomment to Debug your Buffer
    	--Split raw data into data After $GPMRC
    	set AppleScript's text item delimiters to "$GPRMC"
    	set x to text items of Buffer as list
    	set y to second text item of x as string
    	--Extract data before "$GPGGA"
    	set AppleScript's text item delimiters to "$GPGGA"
    	set z to first text item of y as string
    	--Split up data
    	set AppleScript's text item delimiters to ","
    	set GPS to text items of z as list
    	set GPS_TIME to second item of GPS
    	set GPS_Status to third item of GPS
    	set GPS_Latitude to fourth item of GPS
    	set GPS_NS to fifth item of GPS
    	set GPS_LOngitude to sixth item of GPS
    	set GPS_EW to seventh item of GPS
    	set GPS_Speed to eighth item of GPS
    	set GPS_Course to ninth item of GPS
    	set AppleScript's text item delimiters to ""
    	--If Moving store course in Old_Course
    	if GPS_Speed > 1 then
    		set Old_Course to GPS_Course
    	end if
    	--Close Serialport
    	--Is GPS fix valid?
    	if GPS_Status = "V" then
    		display dialog "Lost GPS, Click OK to try again"
    	end if
    	--Convert GPS_Latitude into Decimal
    	set dd to characters 1 thru 2 of GPS_Latitude as string
    	set mm to characters 3 thru 9 of GPS_Latitude as string
    	set mmD to mm / 60
    	set GPS_Latitude to dd + mmD
    	if GPS_NS is equal to "S" then
    		set GPS_Latitude to "-" & GPS_Latitude as string
    	end if
    	--Convert GPS_Longitude into Decimal
    	set ddd to characters 1 thru 3 of GPS_LOngitude as string
    	set mm to characters 4 thru 10 of GPS_LOngitude as string
    	set mmD to mm / 60
    	set GPS_LOngitude to ddd + mmD
    	if GPS_EW is equal to "W" then
    		set GPS_LOngitude to "-" & GPS_LOngitude as string
    	end if
    	--Convert Knots to MPH
    	set GPS_Speed to GPS_Speed * 1.15077945
    	--Convert Time to 12hr time
    	set hh to characters 1 thru 2 of GPS_TIME as string
    	set mm to characters 3 thru 4 of GPS_TIME as string
    	set ss to characters 5 thru 10 of GPS_TIME as string
    	set ss to round ss
    	--Setup time formats
    	if hh > 12 then
    		set PM to "PM"
    	else
    		set PM to "AM"
    	end if
    	set hhh to hh - 12 + TimeZoneOffset
    	set GPS_Time12 to hhh & ":" & mm & ":" & ss & " " & PM as string
    	set GPS_Time24 to hh & ":" & mm & ":" & ss as string
    	--Camera range above ground linked to speed
    	set GPS_Range to 300 + (100 * GPS_Speed)
    	--Camera tilt angle linked to current speed
    	set GPS_Tilt to GPS_Speed * (50 / 100)
    	--Don't change angle data unless moving
    		set GPS_Course2 to GPS_Course
    	else
    		set GPS_Course2 to Old_Course
    	end if
    	--Generate KML File
    	set XMLFile to {class:XML element, XML tag:"kml", XML attributes:{xmlns:"http://earth.google.com/kml/2.0"}, XML contents:{{class:XML element, XML tag:"Placemark", XML contents:{{class:XML element, XML tag:"Name"}, {class:XML element, XML tag:"LookAt", XML contents:{{class:XML element, XML tag:"longitude", XML contents:GPS_LOngitude}, {class:XML element, XML tag:"latitude", XML contents:GPS_Latitude}, {class:XML element, XML tag:"range", XML contents:GPS_Range}, {class:XML element, XML tag:"tilt", XML contents:GPS_Tilt}, {class:XML element, XML tag:"heading", XML contents:GPS_Course2}}}, {class:XML element, XML tag:"Style", XML contents:{{class:XML element, XML tag:"IconStyle", XML contents:{class:XML element, XML tag:"Icon", XML contents:{{class:XML element, XML tag:"href", XML contents:"root://icons/palette-4.png"}, {class:XML element, XML tag:"x", XML contents:"32"}, {class:XML element, XML tag:"y", XML contents:"128"}, {class:XML element, XML tag:"w", XML contents:"32"}, {class:XML element, XML tag:"h", XML contents:"32"}}}}}}, {class:XML element, XML tag:"Point", XML contents:{{class:XML element, XML tag:"coordinates", XML contents:GPS_LOngitude & "," & GPS_Latitude & "," & 0}}}}}}}
    	generate XML XMLFile saving as file "Macintosh HD:Users:Shared:GPS-XML.kml"
    end repeat
    --If you get error "Cannot open port" then the script crashed.
    --Try Runnning this code in a seperate script:
    --serialport close 10
    --serialport close "/dev/cu.usbserial"
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I ran it and got the following:
    1. Couldn't compile the XML stuff but figured I'm missing a scripting addition for that. I commented it out.
    2. It ran, and I got the following:
    "xÜxÃÊ0a…GPGSA,A,1,,,,,,,,,,,,,50.0,50.0,50.0 *05
    $GPGSV,1,1,01,25,00,000,00*4F
    $GPRMC,000820.969,V,0000.0000,N,00000.0000,E,0.000 000,,101102,,*05
    $GPVTG,,T,,M,0.000000,N,0.000000,K*4E
    $GPGGA,000821.969,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7B
    $GPGLL,0000.0000,N,00000.0000,E,000821.969,V*2E
    $GPGSA,A,1,,,,,,,,,,,,,50.0,50.0,50.0*05
    $GPGSV,1,1,01,25,00,"
    Want to:
    Aug 2002
    Austin, TX
    I got it to work.
    I see you also have some giberish at the beginning, I wonder if that is something the GPS units do, or something SerialPortX does.
    But, basiclly when it pulls the serial port buffer the data there is randomly located.
    So what I have it do is first split the data up by "$GPMRC
    " as a list.
    This means that the first chunk of data is always $GPMRC, which has all the info we need to work.
    I think split that bit of data by "$GPGGA" which on my GPS is sent as the next line after $GPMRC, but in your case it looks like it is $GPVTG, so you would have to change that to match.
    But the solution to the script not running more then a frew times is to let the buffer fill to 100% (1020 bytes in the case of my GPS) then read the buffer (effectivly clearing it) then reading about half of it again (512bytes)
    Worked for me, ran for 15 minutes on a test drive.
    Of course there is lots more to do.
    The new code to fix the repeating bug is:
    Code:
    --Let buffer fill up (1020 bytes in my case, set to a high number and watch your script log to see your max number)
    repeat until (serialport bytes available of portRef) >= 1020
    end repeat
    --CLear buffer
    set Junk to serialport read portRef as text
    	repeat until (serialport bytes available of portRef) > 512
    	end repeat
    --Split up data
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    It's working for me now, although I don't get reception in the house, so I get the "GPS Lost" message. Here's the output:
    $GPGSV,1,1,01,19,00,000,00*40
    $GPRMC,003739.862,V,0000.0000,N,00000.0000,E,0.000 000,,101102,,*0B
    $GPGGA,003740.862,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7A
    $GPGLL,0000.0000,N,00000.0000,E,003740.862,V*2F
    $GPRMC,003740.862,V,0000.0000,N,00000.0000,E,0.000 000,,101102,,*05
    If you don't mind, I'm modularizing the script just a little bit. You don't have to use it, but I just wanted to play around with it a little bit to see if I understand how it works.
    Want to:
    Aug 2002
    Austin, TX
    Ya, you will get GPS lost if there is a "V" in the GPRMC line, it stands to inValid.
    There are lots of comments on what each part does, and it's all linear so it shouldn't be to hard to pick around.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I've messed around with it a little bit. It works fine on my system now, although I haven't tested it to see if I can get a lock from the GPS. It ought to work.
    It turns out that you don't need to constantly close the serial port. I also made use of the Record function in Applescript to put all of the GPS info into a list. The main changes were to make most of the program into handlers and move them out of the main repeat loop.
    This was fun and now I'm psyched to work with the serial port. I've got all kinds of stuff I want to do with it.
    Here's the code:
    (*WRITTEN by ZAPWIZARD
    Requires GPSNavX available from here: http://osaxen.com/files/serialportx1.0.html
    and XML RPC*)
    global dev --the serial port device
    global TimeZoneOffset
    set TimeZoneOffset to -6 --Set your Time Zone Offset here
    set dev to FindPorts() --Find out what ports are available
    set portRef to OpenSerial() --Open the port select by the user
    repeat
    delay 0.5
    set GPSBufferData to FillBuffer(portRef)
    set GPSinfo to ParseData(GPSBufferData)
    --Close Serialport
    --serialport close portRef --is this necessary?
    --Is GPS fix valid?
    (*if Status of GPSinfo = "V" then
    end if*)
    GEGenerate(GPSinfo)
    end repeat
    ---------- This handler lists all the available ports ----------------------
    on FindPorts()
    end FindPorts
    ------ This handler opens the serial port ----------------------------------
    on OpenSerial()
    --Open Serial Port
    set SerialPortReference to serialport open dev bps rate 4800 data bits 8 parity 0 stop bits 1 handshake 0
    if SerialPortReference is equal to -1 then
    serialport close SerialPortReference
    serialport close 10
    --Try again
    log "Failed to open serial port"
    return false
    end if
    end if
    log "Serial port opened"
    return SerialPortReference
    end OpenSerial
    -----This handler fills the buffer from the serial port ---------------
    on FillBuffer(myPortRef)
    repeat until (serialport bytes available of myPortRef) ? 1020
    end repeat
    --CLear buffer
    set Junk to serialport read myPortRef as text
    repeat until (serialport bytes available of myPortRef) > 512
    end repeat
    set Buffer to serialport read myPortRef as text
    return Buffer
    end FillBuffer
    -----This handler receives a buffer with the GPSData inside it and ---------------
    -----splits it into the right bits of information by putting it into -------------
    -----a record, then returning that record -------------
    on ParseData(GPSBufferData)
    --Split up data
    --Look at the buffer data and find where it begins with $GPMRC
    set x to text items of GPSBufferData as list --This put the data that begins with $GPRMC into a list
    set y to second text item of x as string --This sets a string variable that contains only the data itself
    --Look at the Y data and find where it contains "$GPGGA"
    --Split up data
    set GPS to text items of z as list --Here's where the good stuff like position, speed, course, etc. are stored in a list
    set GPSdata to {GPStime:second item of GPS, Status:third item of GPS, Latitude:fourth item of GPS, NS:fifth item of GPS, Longitude:sixth item of GPS, EW:seventh item of GPS, Speed:eighth item of GPS, Course:ninth item of GPS, OldCourse:0}
    return GPSdata
    end ParseData
    -----This handler receives a record with the GPS info in it. ---------------
    -----It uses this record to generate a KML file for Google Earth -------------
    -----tracking -------------
    on GEGenerate(geGPSinfo)
    set dd to characters 1 thru 2 of Latitude of geGPSinfo as string
    set mm to characters 3 thru 9 of Latitude of geGPSinfo as string
    set mmD to mm / 60
    set Latitude to dd + mmD
    if NS of geGPSinfo is equal to "S" then
    set Latitude of geGPSinfo to "-" & Latitude of geGPSinfo as string
    end if
    set ddd to characters 1 thru 3 of Longitude of geGPSinfo as string
    set mm to characters 4 thru 10 of Longitude of geGPSinfo as string
    set mmD to mm / 60
    set Longitude of geGPSinfo to ddd + mmD
    if EW of geGPSinfo is equal to "W" then
    set Longitude of geGPSinfo to "-" & Longitude of geGPSinfo as string
    end if
    set Speed of geGPSinfo to (Speed of geGPSinfo) * 1.15077945
    set hh to characters 1 thru 2 of GPStime of geGPSinfo as string
    set mm to characters 3 thru 4 of GPStime of geGPSinfo as string
    set ss to characters 5 thru 10 of GPStime of geGPSinfo as string
    set ss to round ss
    if hh > 12 then
    set PM to "PM"
    else
    set PM to "AM"
    end if
    set GPS_Range to 300 + (100 * (Speed of geGPSinfo))
    set GPS_Tilt to (Speed of geGPSinfo) * (50 / 100)
    if Speed of geGPSinfo > 1 then
    set GPS_Course2 to Course of geGPSinfo
    else
    set GPS_Course2 to OldCourse of geGPSinfo
    end if
    --Generate KML File
    --generate XML XMLFile saving as file "Macintosh HD:Users:Shared:GPS-XML.kml"
    end GEGenerate
    Want to:
    Aug 2002
    Austin, TX
    Thanks for the edits.
    I have fixed some bugs in yours (typos mostly)
    I added a MPH readout as a seperate placemark.
    I also split out the XML code, finally found the dang carriage return button.
    The code is located here (too long to post)
    http://www.zapwizard.com/GPS.scpt
  1. Ways to pull in NMEA data?
    By Viscouse in forum Road Runner
    Last Post: 01-02-2006, 10:58 AM
  2. sirf or nmea in MP?
    By johnwrx in forum GPS
    Last Post: 11-09-2005, 05:44 PM
  3. How to switch to sirf from nmea & push to fix mode
    By qbee in forum Software & Software Development
    Last Post: 03-07-2005, 06:59 PM
  4. AppleScript Resorces?
    By iwakura in forum MacCar
    Last Post: 01-22-2005, 07:37 PM
  5. Replies: 2
    Last Post: 11-11-2004, 04:51 AM
