Page 2 of 19 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 182
Thread: Harmony - Mac Front End Worklog
  1. #11
    Jul 2005
    Atlanta
    Quote Originally Posted by Bugbyte
    There's no reason we can't release one. I haven't looked into how to do it, but given that it's AS, it should be straightforward.
    It's straightforward in any language XCode can handle. Right-click your main project in the main window, select Get Info, go to the Build tab, select Architectures from the Collection: box, select the Architectures setting in the list, click Edit, and check the Intel box.
  2. #12
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Done. Now it's Universal Binary.
    Want to:
  3. #13
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Hey, i'm not on the Mac bandwagon, but i'll post here the XM protocol specification PDF that I have in case it's any use to you guys. As far as I can tell also, the XM-PCR and XMD-1000 are basically the same unit, only the PCR is USB and the XMD requires the assembly or purchase of a custom serial cable. Like i said, not sure if it helps, but I like to help a fellow developer if/when i can
  4. #14
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thanks! I scarfed your doc from the other thread and that's how I knew that the PCR works that way. Thanks for posting it up!
    Want to:
  5. #15
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    is there going to be an ODBII component?
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
  6. #16
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Update 2: 3/14/2006
    Worked a bit last night on some of the bugs in the iTunes player. We added a "Home" page so you don't have to use those little tabs across the top and can jump directly to the section you want. I've made that a preference so if you always want to start with Music, you can. That's what I'd prefer.
    The bug surfaces when you select any function other than music as the default start view. The app tries to populate the playlist and music track names with the last playlist you were listening to and the tracks from that playlist. If the music tab isn't displayed at the time, you get an error. I fixed it by switching to that view, setting it up, then switching back to the 'Home' page. Only problem is, you can't do that while the window is not shown so you see it switching to Music, setting up, then switching back.
    I need to see if I can set the window to transparent, set it up, then make it opaque.
    Want to:
  7. #17
    Feb 2006
    [QUOTE=Bugbyte]Worked a bit last night on some of the bugs in the iTunes player. We added a "Home" page so you don't have to use those little tabs across the top and can jump directly to the section you want. I've made that a preference so if you always want to start with Music, you can. That's what I'd prefer.
    Not that I'm a programmer, but couldn't you just have it somehow cache, the last thing it was doing? last song? movie? XM station? and just load that upon restarting the program or computer?
  8. #18
    Newbie minicoopS007's Avatar
    Sep 2005
    Gaithersburg
    [QUOTE=LightningMac]
    We're using the preferences file to keep track of our application specific prefs i.e. last xm station, last iTunes song, brightness control, etc. Right now we're using one prefs file but we intend to move to a prefs file for each app (Music, video, xm etc).
  9. #19
    Feb 2006
    Lookin great! Any chances of support for Mitches sirius interface?
  10. #20
    Sep 2005
    Gaithersburg
    AppleScript Log
    comrades i need your applescripting expertise. We have an HXM application that controls XM direct and needs to be applescriptable from Harmony. I've created a .sdef file and build with no errors. When I try and access HXM through and applescript I get the following error from the console.log:
    Code:
    2006-03-14 21:28:26.114 HXM[1455] Suite HXM, apple event code 0x48786d72
    2006-03-14 21:28:26.137 HXM[1455] .scriptSuite warning for result type of command 'channel' in suite 'HXM': the type NSNumber ('long') doesn't match the result Apple event code ('nmbr').
    2006-03-14 21:28:43.199 HXM[1455] Command: HXM.setChannel
    	Direct Parameter: 48
    	Receivers: (null)
    	Arguments: {"" = 48; }
    2006-03-14 21:28:43.199 HXM[1455] Result: (null)
    2006-03-14 21:28:43.217 HXM[1455] Command: HXM.channelTitle
    	Direct Parameter: (null)
    	Receivers: (null)
    	Arguments: {}
    2006-03-14 21:28:43.218 HXM[1455] Result: (null)
    It looks like HXM receives the command and returns a null, why a null? I've harded coded channleTitle to return "TEST".
  1. which front end for no touch screen?
    By turbochris in forum Newbie
    Last Post: 08-30-2005, 09:59 AM
  2. This is an awesome front end, and here is why:
    By WhiteRabbit in forum NeoCar Media Center
    Last Post: 08-27-2005, 09:43 PM
  3. Front End Challange!
    By SEGgeek in forum MacCar
    Last Post: 08-16-2005, 10:16 AM
  4. Front end needed for semi commercial venture
    By Orange Bus in forum Software & Software Development
    Last Post: 04-28-2005, 01:59 AM
  5. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 08:33 AM
