Results 1 to 6 of 6
Thread: Mac Developers - Can you answer this question?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I took ZapWizard's Google Earth GPS script and put it into an applescript application, adding a GUI that tells you your speed.
    In order to get it to work, I had to use a serial and XML scripting addition (OSAX's). I built the app, got it to work on my development machine, then transferred the app to my in car Mac Mini.
    It doesn't launch. It bounces on the dock 5 or 6 times and then disappears. I thought it was a problem with the OSAX's, so I put them in my Library-->Scripting Additions folder but got the same result.
    Any ideas of how to debug this?
    Want to:
    Jul 2005
    Atlanta
    I've run into this before - an app will work fine on the machine it's compiled on but not on anything else. In XCode (I'm assuming that's what you're using), go to Project > Set Active Build Configuration > Release and it should start working.
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    You might also check your logs (Applications -> Utilities -> Console). Typically if something is crashing you'll see something in either the console or system logs.
    I know the above suggestion is important for a Obj-C (and I assume Java) app, but I don't know about AS though it couldn't hurt.
    Also make sure that the Serial and OSAX extentions are installed in the same place as your build machine (though Release vs Debug usually takes care of that kind of thing).
    -dave
    Jul 2005
    Atlanta
    It does happen with AS... I first encountered it with an Applescript frontend I was working on a while ago. It's not exactly a cure-all, but it could definitely help.
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    Quote Originally Posted by Mahalis
    Exactly. Just for info: the actual reason the application does not run is the ZeroLink, which is disabled in Deployment/Release build style but enabled in Development/Debug. Without many details: ZeroLink is the feature that allows you to modify the application while it is running.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Ah! Okay, that worked. I still have to have the scripting additions in the right place or it doesn't work -unfortunate.
    At least I can try it out, though. Thanks for the info!
    Want to:
  1. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 10:16 PM
  2. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 04:25 PM
  3. MOtorized LCD that flips down?
    By AdamChrap in forum LCD/Display
    Last Post: 02-01-2006, 10:16 PM
  4. PLEASE answer this question for me Re: GPS button
    By Sonicxtacy02 in forum FrodoPlayer
    Last Post: 12-25-2004, 03:49 PM
  5. quick lcd question! anyone whos done one knows the answer!
    By minnow255 in forum General Hardware Discussion
    Last Post: 09-12-2000, 04:31 AM
