Wow, if you posted this in the netstumbler forums it would be like insta-ban. Mainly due to the fact that stealing it bad, but also due in part to poor grammer.
http://www.buffalotech.com/products/...&categoryid=29
AirStation Turbo G High Power Wireless Ethernet Converter
Model: WLI-TX4-G54HP
Features:
• High Power Wireless Increases Performance by up to 70% and Extends
Range by up to 50%
• 802.11g Wireless 125* High-Speed Mode™ (Turbo G) Transfer Rates when Used with 125* High-Speed Mode™ (Turbo G) Access Points or Wireless Routers
• Four Built-in 10/100 Ports for up to 4 Simultaneous Wired Devices
• Easy and Secure Wireless Connections with AOSS™
• Can be Used Horizontally or Vertically
• Compatible with 802.11b and 802.11g Wireless Routers and Access Points
• Simple Web Browser Configuration, No Drivers Needed
• Can be Moved from Device to Device without Reconfiguration
• Enhanced Security with WPA (TKIP, AES) and Standard 64/128-bit WEP
• Works as a High-Speed Wireless Gaming Adapter
OMG i use this with my ibook to steal unsecure wireless networks, without having to leave the house.
ok i test it everytime i use it. with airport i get a signal of -22db. with the adapter i get results twice as better.
it's not 100% mobile cuz it needs a power adapter, but pushes in results u want
Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
Better than winamp. Click here for qcd player.
