Results 1 to 8 of 8
Thread: Some Cocoa/XCode help
    Dec 2005
    London, UK
    Hi guys,
    I know this not the right place to ask this type of questions but I didn’t find any better place either. Sorry for that.
    I’m having some trouble using NStextField with NSView - when I run the programme the text box becomes inactive. But the same programme if I create using NSWindow (in stead of NSView) it works fine. I created a NSView sub-class in XCode, drag the .h file to IB, instantiate the class and put a NSTextField in there. I'm creating the window the programmatically. Am I doing any thing wrong?
    Thanks a lot in advance!!!
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    I think i'm a bit confused. Are you creating the View/Window dynamically and then adding TextFields?
    If your Window and it's objects are static, then why aren't you using a NIB and linking to the objects that way?
    If you are trying to do it dynamically, then I have no idea Try the cocoa-dev list and see if you can find anything there.
    -dave
    Dec 2005
    London, UK
    Sorry, I wasnít that clear. Iím trying to explainÖÖ
    Iím using borderless window for my app and only the borderless window Iím drawing dynamically but not any other controls. So, say, AppController is a subclass of NSObject, so I have:
    #AppController.h
    Code:
    #import <Cocoa/Cocoa.h>
    @interface AppController : NSObject
        IBOutlet NSView *aView;
        NSWindow *aWindow;
    @end
    and then in the AppController.m
    Code:
    #import "AppController.h"
    @implementation AppController
    - (id)awakeFromNib {
    	aWindow =[[NSWindow alloc] initWithContentRect:NSMakeRec(150,30,500,361)
    	  styleMask:NSBorderlessWindowMask|NSTexturedBackgroundWindowMask
    	  backing:NSBackingStoreBuffered
    		defer:NO];
    	[aWindow setContentView:aView];
    	[aWindow makeKeyAndOrderFront:nil];
    	[NSMenu setMenuBarVisible:NO];
    	return aWindow;
    @end
    And then using the NIB Iím adding the textFiled to the NSView (aView). Am I clear now? Befor posting it here I tried several cocoa-dev list/forum but didnít get anything helpful.
    Jul 2005
    Atlanta
    Um... why not just create your own BorderlessWindow class and set a window in IB to have that as its custom class?
    Jul 2004
    NoVA
    Quote Originally Posted by Mahalis
    Or use a normal window and change it's attributes in the awake from nib method (and default it's visable setting to off so that the user doesn't see the changes happening).
    -dave
    Jul 2005
    Atlanta
    You can't set a window's style mask after it's been created. The only way to get a borderless window is to create a new one in code - which is, as far as I can tell, the problem here - or to subclass it and override initWithContentRect:.
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    Borderless window does not accept key window status by default, so NSTextField or other keyboard-controlled widget will not work there.
    You have to sub-class the NSWindow:
    Code:
    @interface MyWindow:NSWindow{}
    @end
    @implementation MyWindow
     -(BOOL) canBecomeKeyWindow{
      return YES;
    @end
    Then you can replace NSWindow with MyWindow in the code you quoted above and your borderless window will accept key events the same way as a regular window.
    Dec 2005
    London, UK
    Thank you all for your suggestions. Jirkaís three lines worked just perfect for me. Itís working now.
