Results 1 to 6 of 6
Thread: Mac Mini Users
    Apr 2005
    monroe/louisiana
    Mac Mini Users
    I followed Bugbytes work log and created two duplicates of his dock. but before i start permanently sealing these wires in. What are ya'll plugging into your usb ports?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Cool! Post some pics of it!
    I plugged my touchscreen into one port and a 4 port USB hub into the other. That has a Griffin Powermate and a keyboard, an open port for flash disk, and a spot for the GPS whenever I get it working.
    Want to:
    Apr 2005
    monroe/louisiana
    ok i went with the touchscreen and a usb hub.
    Here's some pics of the dock, Bugbyte. also, what did you use to make a handle? i've notticed that connecting it all the way in and pulling it out isn't going to be as easy as i thought.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Very cool! Looks like it's coming together.
    I used a piece of flat aluminum for the handle. I got it at Home Depot for a couple of bucks. Then I used a beltsander to make it look like it was 'brushed' aluminum.
    Here's my worklog entry showing how I did it.
    Want to:
    Apr 2005
    monroe/louisiana
    holy crap. that's way beyond my workshop lol or mcguyver knowledge. have anyother suggestions on how to do it. or! interested in fabbing another for some dough?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    No, no! It's simple. Really. I put the Mini down on a piece of paper and traced the outline. Then, I cut the outline out and taped it to a piece of 1" thick wood and transferred the outline to the wood. (I suppose you could just trace the Mini directly on the wood).
    Then, I cut the wood out using a band saw, but a jig saw would also do. You can bend the aluminum by hand, and that's what I did. I actually cut the piece of wood at about a 93 degree angle so I could 'overbend' the aluminum and it would snap back to 90 degrees.
    If you don't want the slider on the handle, just drill a hole. The tap and die wasn't very expensive and worked easily on the first try.
    It's a piece of cake. There's really no risk until you drill a hole in the side of the Mini. (Did I mention that you should take the case off before you do that :-)
    Want to:
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 11:16 PM
  3. Mac Mini in a Mazda Protege
    By zapwizard in forum Show off your project
    Last Post: 08-07-2006, 09:18 AM
  4. FS: Mac Mini CarPC Package/Parts LOADED!
    By markcc01 in forum Classified Archive
    Last Post: 01-03-2006, 11:47 PM
  5. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 01:25 PM
