Results 1 to 10 of 10
Thread: New Install Range Rover 06
    May 2005
    I bought a new range rover and didn't see a need for a mac installed in my car so I've gone a few months with just the factory bluetooth phone, nav and touchscreen functions. I miss the mac in my car so I'm going back but I don't want to loose the factory functions. Is there a way to hack in and allow the mac mini on a different video source to still be able to have touchscreen features.
    Also is there a way to run a script to have front row launch everytime the mac is booted. This is going to be my main interface with everything.
    Also has anything changed with power supplies? Are we still using the p1900? Any suggestions of what I should do on this new install? I HAVE NO BUDGET!!
    Im also interested in getting the same image on the my headrest monitors? Do i need VGA? do I need a converter? Please help me pimp this thing out!
    Aug 2004
    sorry man... I don't think you can use 06 Range Rover and NO BUDGET in the same post!
    May 2006
    If you want Front Row to auto load when OS X loads, go to SYSTEM PREFERENCES > ACCOUNTS, and click on the LOGIN ITEMS tab. Select Front Row as one of the login items and you're set.
    Variable Bitrate skippy911's Avatar
    Feb 2005
    I did that but it doesnt work. I trid both the com.apple.frontrow.plist and frontrow.pkg what am I doing wrong?
    Jan 2006
    Quote Originally Posted by Vinister
    i think he means there is no amount of money he won't spend
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by brandondente
    I HAVE NO BUDGET!!
    Sorry, but Range Rover <> No budget.
    Consider that an inverter costs $50. Consider that the P1900 costs $100. You're out $50 no matter what. That makes the marginal cost of the P1900 $50. In other words, it's not a $100 purchase, it's a $50 increase in the budget.
    That should make you feel better.
    Want to:
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    No idea, but some enterprising people managed to do it with the Toyota Prius interface so it *might* be possible.
    You can write an AppleScript that sends the keycode for the "Menu" option, then put that in your startup. Search around or go ask in the FrontRow Remote thread, i'm sure they can tell you since they do it
    Is there any reason to mess with success
    Mike does have a couple of things in the pipe though (like the MacPac so you don't have to splice your power supply cable.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    Feb 2005
    Got it working thanks. i found this in the frontrow thread:
    tell application "System Events"
    tell application "Front Row" to activate
    key code 53 using {command down} -- escape
    end tell
    Works perfect. I saved it as an application and set it to autorun on startup YAY!
    May 2005
    Thanks for everybody's help.
    What needs to be modified on the p1900 for the intel mac mini?
    Also, refering to the "No budget" I don't care about cost. I was looking for suggestions or ideas to do to my new car computer and not be limited to the cost.
    Feb 2005
    You need to put a resitor in the p1900 there are instructions on www.carnetix.com
  1. install on 06' civic
    By Aspenkarius in forum General MP3Car Discussion
    Last Post: 12-01-2006, 12:20 PM
  2. I want to install a switch
    By Froogle in forum Power Supplies
    Last Post: 04-13-2006, 11:12 PM
  3. Rover Turbo Install
    By skydiver in forum Show off your project
    Last Post: 02-11-2005, 04:12 AM
  4. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 06:40 PM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
