Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 63
Thread: Help with my intel mini and p1900
  1. #51
    Variable Bitrate skippy911's Avatar
    Feb 2005
    Its wired up correctly now. I just have to find time to drive out to frys and pick up another one.
  2. #52
    Feb 2005
    Ive been running my mini in the car for the past 2 days and it never seems to have a problem waking on usb. IE I dont have anything plugged into a hub just straight into the mini. I have my usb sound and usb touchscreen plugged it. Is the wake on usb perhaps not active on intel mini's? Also, is there a way to auto start playing the music again when the mini comes back from sleep? I hate having to press play everytime I turn the car on.
  3. #53
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by skippy911
    It's device dependant. For instance, if you have a mouse attached and it moved or a button got clicked (again device dependant) it would wake the Mini. All devices have the pontential to do it, it's just a matter of if they are built that way and what needs to occur for them to send the signal (i've heard GPS recievers will do it when they pick up different sattelites).
    There was a thread about this awhile ago. I think the jist was that there is some program out there that allows you to run things when the computer wakes up. Then you write a simple apple script to tell itunes to play.
    EDIT: Here is the thread.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
  4. #54
    Feb 2005
    Ok cool Ill have to do some testing with those scripts thanks. BTW I learned today a bluetooth keyboard will wake the damn mini up as well. I wish there was a way to turn off this wake on usb, wake on bluetooth nonsense.
  5. #55
    Feb 2005
    I got everything working perfectly in the lexus now with regards to the mini and p1900. Ill post some pics tomorrow Thanks for all the help guys.
  6. #56
    Feb 2005
    Oh an incase anyone is wondering, I am not using bootcamp anymore I am using parallels and iguidance. Works great. Windows will still play all sounds through it while itunes is running so I can still hear the voice prompts. Also I setup a keyboard shortcut on my bt keyboard to switch b/t windows and osx. Alot faster to use parallels then to boot using bootcamp. Now if parallels made a frontrow plugin I would be set! Hehe.
  7. #57
    Jul 2004
    NoVA
    No problem. Glad it all worked out in the end
    -dave
  8. #58
    May 2006
    Parallels is pretty nice. Glad you got it all sorted out. Pics!!!
  9. #59
    Newbie Jagwire's Avatar
    Apr 2006
    Tacoma, WA
    here is my deal... figured i'd post on this thread rather than starting a new one because my problems are similar. I turn the key mini doesn't turn on, screen turns on amp turns on. If I wait the initial 60 seconds and turn the car off the mini then turns on and boots up with the car off?!? K so I turn the car back on and the mini is now on and everything works, when i get out and turn the car off again the mini sleeps like it should. When i return to the car the mini is off again. I'm getting ****ed folks.
  10. #60
    Jul 2004
    NoVA
    Quote Originally Posted by Jagwire
    Sounds like:
    1) Your battery is low and the Mini is draining enough during sleep mode to send it below the threshold where the P1900 will kill it.
    2) Some USB device is connected that is still powered up (the Mini's USB ports are active when it is sleeping) and is doing something to cause the Mini to wake. In which case the P1900 will kill it as it knows something is wrong.
    -dave
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Audio issue with Intel Mini
    By iamgnat in forum MacCar
    Last Post: 06-27-2006, 08:01 PM
  3. Intel Mini and standby?
    By smkau18 in forum MacCar
    Last Post: 05-23-2006, 10:55 PM
  4. 2 x 2006 Scion xB + Mac Mini (Intel)
    By TnT_xB in forum Show off your project
    Last Post: 05-08-2006, 12:17 AM
  5. Intel Mac Mini on TrailBlazer 2002
    By tizoc in forum Newbie
    Last Post: 04-19-2006, 02:03 PM
