Page 7 of 7 FirstFirst 1234567
Results 61 to 63 of 63
Thread: Help with my intel mini and p1900
  1. #61
    Newbie Jagwire's Avatar
    Apr 2006
    Tacoma, WA
    it could be the first one i will try charging my battery tonight and see if that helps, the 2nd one however i only have my touchscreen plugged into the usb ports and the power gets killed to that when i turn the ignition off
  2. #62
    May 2006
    You sure you have the jumper on the p1900 set to standby and not hibernate? I had a similar problem with mine. The p1900 was cutting power after ~1 minute.
  3. #63
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by Jagwire
    You might confirm in the LCD forum, but I believe the touch screen draws it's power from USB rather than the power source that the LCD uses. If that is the case it *could* be the issue. You might try disconnecting it and see if that changes anything. It's a cheaper test than a new battery anyway (unless you suspect it is not holding a charge for some other reason)
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Audio issue with Intel Mini
    By iamgnat in forum MacCar
    Last Post: 06-27-2006, 08:01 PM
  3. Intel Mini and standby?
    By smkau18 in forum MacCar
    Last Post: 05-23-2006, 10:55 PM
  4. 2 x 2006 Scion xB + Mac Mini (Intel)
    By TnT_xB in forum Show off your project
    Last Post: 05-08-2006, 12:17 AM
  5. Intel Mac Mini on TrailBlazer 2002
    By tizoc in forum Newbie
    Last Post: 04-19-2006, 02:03 PM
