When you turned the ignition off did you wait 60 sec for the p1900 to get out of shutdown lockout mode before you turned the ignition on again. If you turn the ignition on while the p1900 is in lockout mode the p1900 will not startup. There is also a bootup lockout that stops the pc from turning off before its fully booted.
LinkBack URL
About LinkBacks
