Results 1 to 9 of 9
Thread: Griffin PowerMate Causing Mac Mini to crash!
    Jun 2006
    Hi there I found no one has the same problem as I do:
    My Griffin PowerMate is installed on my Mac Mini Core Solo. Since I installed it I have a (I think it is called) kernel panic at shutdown. Have any of you had this issue?
    Thanx for the feedback...
    Mac-in-a-Zuk
    Suzuki Jimny 1.3 VVT - Mac Mini 1.5GHz Intel Core Solo - 7" Newision NW619VT touch screen - 2x200W amp
    Jun 2006
    Unhappy
    Hi!
    Seems no one has the same problem as I have. So I will give you an update on the situation:
    I installed the UB 1.6.4 version of the Griffin PowerMate software. That went OK and then I plugged the PowerMate in, that went OK too and the knob works. But when I shutdown it panics! so I tried some variations first I just unplugged the PowerMate and then shutdown... and it worked fine no panics
    Then I decided to go to my Apple reseller and ask him to test it, he actually just sat me down in front of another Mac Mini Core Solo 1.5GHz and said I could do what I wanted! I thought that was pretty good stangely the PowerMate worked on the shop's Mac Mini. So I have come to the conclusion the the PowerMate is incompatible with my configuration.
    Now I have 2 external devices plugged into the USB ports: 1 is the touch screen, the other is the griffin RadioShark. I suspect very strongly that the UB version of the Touch Screen from www.newision.com is conflicting with the UB version of the PowerMate software/driver.
    If anyone has a Mac Mini Core Solo 1.5GHz coupled with a Touch screen and a PowerMate and the setup works sucessfully can he/she tell me as I would be very interested to find a solution to my problem.
    Thanx all
    Mac-in-a-Zuk
    Constant Bitrate Sharkbite86's Avatar
    Apr 2006
    California
    maybe you sould try pluggin it into a powered hub? Or for a more drastic approch yo could reinstall everything one at a time to find the issue... I think i heard somwhere that the powermate was not completely compatible with intel macs (although I could very well be wrong). email griffin and the touchscreen folks with your problem and see if they can help.
    MacCar progress:
    Planning:-----> [||||||||||||||||||||] 70%
    Parts:---------> [||||||||||||||||||||] 0%
    Construction:-> [||||||||||||||||||||] 0%
    Car broken into... progress is basically zip...
    Constant Bitrate MacMobile's Avatar
    Sep 2005
    Trois-Rivieres, Qc, Canada
    Quote Originally Posted by saabman96
    Hi!
    I have a G4 Mac-Mini, Xenarc Touch screen and many USB accessories going through two USB Hub and I did had some problems. There are only two USB ports on G4 Mini so I had a hub in each port. I was told to plug the touch screen directly into the Mini and the rest through the hub and my problem was solved.
    Not sure about the Intel Mini but my best guest would do like Sharkbite86 suggest car start by writing to Grffin to see if they have received report of problem with Intel Mini.
    Good luck.
    Franco
    Help me keep my web site up to date.
    Mac-Mini in Passat
    Jun 2006
    Thumbs up
    Thanx for you advice I will check with Griffin first
    Mac-in-a-Zuk
    Variable Bitrate skippy911's Avatar
    Feb 2005
    It does not work with intel mini;s. Griffin knows this, I verfied this, and took the power mate back to the store. I would recommend you do the same.
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    sure it does!
    I've got a griffin powermate i purchased about a month ago or so and it works famously on my intel mini. I've got the Core Duo 1.6Ghz. I'll qualify that by saying that I did download the latest drivers from their website and am using no software or drivers other than what I needed for Front Row.
    Dec 2005
    Hi All,
    I have the same problem with my intel mac 1.5 solo and powermate. Any solution yet saabman? did you contact griffin?
    thanks
    Jun 2006
    I am affraid that it does not work with the core solo but it does fine with the duo, I tested it at the shop, but had to hand it back as we couldn't get it to work ...
    Mac-in-a-Zuk
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 10:16 PM
  3. Mac Mini in a Mazda Protege
    By zapwizard in forum Show off your project
    Last Post: 08-07-2006, 08:18 AM
  4. Intel Mac Mini on TrailBlazer 2002
    By tizoc in forum Newbie
    Last Post: 04-19-2006, 01:03 PM
  5. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 12:25 PM
