Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Mac Mini Auto Boot - (bypassing power button)
  1. #11
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    The second one will definitely work. For it to light up, you have to supply it with 3 volts of power. The first one may work but I couldn't tell if it was momentary contact or not.
    Want to:
  2. #12
    Dec 2005
    London, UK
    Quote Originally Posted by Bugbyte View Post
    Thanks Bugbyte. The second one will match my MacMini environment as well. For the "light", as original MacMini power button has a light in it, so simply using a y-adapter will do the job? Cheers!!!
  3. #13
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    IF the voltage requirement for the two lights is the same, I'd say, yes that you could do that. The other option is to simply use an LM317 linear regulator from Radio Shack and supply your own power. It'll cost you a total of about $6 bucks for the regulator and the resistors.
    http://www.radioshack.com/product/in...entPage=search
    Want to:
  4. #14
    Constant Bitrate onepuff's Avatar
    Jan 2006
    Quote Originally Posted by MacUsers View Post
    What MacMini power button comes with a light? I had some switches like the ones in the second link before. I think i ran them off the p1900 p5v output with no problem.
  5. #15
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Uh, yeah, that's what I meant! I think the iBook has the button light. The Mac Mini has the LED. Maybe you could power it from that.
    Want to:
  6. #16
    Dec 2005
    London, UK
    Quote Originally Posted by onepuff View Post
    It isn't? I think I saw a warm green'ish light when it's on. I'm gonna check in a min.........
  7. #17
    Dec 2005
    London, UK
    I was wrong; doesn't look like Off/On button is illuminated. I also see that there is only two wire attached at the back of the button. So, am I in trouble if I wanna use an illuminated one? I'm not using p1900/p5v as the Mini in my kitchen, in stead of car. Cheers!!!
  8. #18
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Look at the power LED. You can probably power the button's LED light by tapping into that.
    Want to:
  9. #19
    Dec 2005
    London, UK
    You mean the LED in the front (below the optical drive slot) and making a connection from there to the button for the LED? Cheers!!!
  10. #20
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yep, that's the one I mean.
    Want to:
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. mac mini core solo enough for bootcamp?
    By replicant in forum MacCar
    Last Post: 06-27-2006, 12:49 AM
  3. Power Button, Shut Down Help Please!
    By FireAnt in forum MacCar
    Last Post: 05-02-2005, 03:25 AM
  4. Replies: 21
    Last Post: 04-05-2005, 10:54 AM
  5. Replies: 2
    Last Post: 02-01-2005, 01:13 PM
