Results 1 to 9 of 9
Thread: For an install what do you recommend
    Mar 2004
    If I ever get around to doing an MacCar install. What mini should I be looking at to do everything I would want (MP3, DVD, FM/XM, CD and GPS) maybe running external firewire DVD drive with a front end program as well.
    I know the size of the hard drive will need to be increased to meet my storage needs, but how much RAM and what speed processor should I look at to run something like this?
    AMP Creator aychamo's Avatar
    Jun 2006
    Honestly, you should be fine with the single core processor. I'd go with 1 gig of ram for sure.
    Jun 2006
    For a front end, I'd reccomend AMP
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    Single core, 1GB RAM. An external FireWire DVD drive sounds like a good idea, since it is easier to mount than the mini itself. I would not worry too much about the hard drive capacity. Either use a large external drive or a portable FireWire/USB drive which you can easily update at home (i use iPod this way).
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by aychamo
    Biased much
    I was worried my single core would be too wimpy (but wasn't going to pay the dual price for a glorified MP3 player). I was REALLY worried playing with it in the house. But then my 1GB chip showed up and all has been good. My rule of thumb is that you have to have 1GB of memory minimum (I kept one of the 256 chips in so I have 1.25GB) in any Mac for the best performance and it appears to hold true with the Intel Macs too.
    For storage, you can upgrade the internal drive when you do the memory (I believe that 2.5" drives are up to 200GB now), or go with an external. Depending on your space, there is an external made to sit under the Mini.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    The more memory the better for any Unix os. I like the idea of an external firewire drive. Makes moving really large files so much easier. Also helps for making backups. Install a minimal osx on the firewire drive. Boot the mini off that and make a disk image of the mini's drive and save it to the firewire. If anything happens to the mini, you can restore from the image. That's pretty much how we do it at work.
    Failure is not an option....
    It's installed by default on every version of Windows.
    Mar 2004
    Ok so it seems the Core Solo should be fine as long as I have 1 gb of ram. as for the hard drive space you guys do bring up a good point, if I find a place to mount it that has room for an external drive, I know a P1900 will power a mini and a touch screen, but how hard is it to power another thing such as a external HD off a P1900?
    Jul 2005
    Netherlands
    Quote Originally Posted by Valhalla
    If you use FireWire or a low-power device (like an iPod), you should be able to power the disk thru the computer. If no, look for drives that can take 12V directly and just connect it to the car's battery directly. I have an old LaCie HDD, that takes anything between 8V and 30V DC...
    Constant Bitrate godraj's Avatar
    Jan 2006
    east coast NY
    I'm using core solo with 1gb ram (2 * 512mb). I was worried before I got it that it would be slow, but once I got it and i installed everything on to it it has been great. I compared the speeds of running parallels against a macbook duo with 2gb ram, and the macbook was about 2-3 seconds faster. So I think the solo with 1gb is enough for a car setup atleast.
  1. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 05:25 PM
  2. I want to install a switch
    By Froogle in forum Power Supplies
    Last Post: 04-13-2006, 11:12 PM
  3. Trying $145 Migrus P4 itx for second install
    By VehicrossPC in forum General Hardware Discussion
    Last Post: 02-25-2006, 10:03 PM
  4. Replies: 2
    Last Post: 10-20-2005, 08:42 AM
  5. How much airflow / fans for this install - pics
    By Pabs in forum General Hardware Discussion
    Last Post: 12-22-2004, 11:08 AM
