Results 1 to 7 of 7
Thread: Audio Input Question
    Jul 2006
    Raleigh, NC
    I'm in the process of building my first carputer. I have a 12" Powerbook with an M-Audio Sonica Theater USB soundcard running my amps. I don't use a headunit, nor do i want one. I've added a sirius radio to the mix and need to use an audio input. The powerbook does not allow audio passthrough, but the M-Audio does. Now for the trouble. the input works intermittenly. it will work when i monitor the input, after i turn it off and back on the M-audio piece no longer recognizes the input. Is there a better solution? I also would like to eventually add a playstation / x-box something like that... and will need some a/v inputs that work. I've searched, I've read everything to read, and still come up empty. any help would be appriciated. thanks
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I've used a Griffin iMic with good results. The Mac generally doesn't lose track of the iMic. I use the program Line-in to monitor the input.
    Want to:
    Jul 2006
    Raleigh, NC
    thanks for the help. I'll have to give that a try if i can't get this POS to work. one thing i liked about the M-Audio peice that i don't see on the Imic is dolby surround outputs. I Hope i can figure a way around that.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Well, you ought to be able to route the audio in via the iMic and out via the M-Audio. LineIn lets you set the input and output devices.
    Want to:
    Jul 2006
    Raleigh, NC
    I tried that setup this morning without the Imic, just using the audio input on the computer, and the output routed to the M-audio, and it worked perfectly! LineIn was just the program I was looking for. Thanks!
    Jun 2006
    I'm going to try this as the audio solution for my PS2, since video is handled by an RCA input on the screen.
    Feb 2005
    Like bugbyte, I too have found the imic (older version) to be very reliable and gives good results.
    Has anyone tried to run 2 imic's ?
    __________
    rgds, raceer
  1. Custom auxiliary audio input?
    By xjeff in forum Input Devices
    Last Post: 05-20-2006, 10:16 PM
  2. Audio question
    By Meneerdeman in forum Car Audio
    Last Post: 04-08-2006, 05:22 AM
  3. running stereo audio to rf cd changer input
    By wh00ps in forum Car Audio
    Last Post: 02-27-2005, 11:01 PM
  4. FV24 Audio Question
    By komarak in forum General Hardware Discussion
    Last Post: 01-11-2005, 03:57 PM
  5. Renault Master VanPC and audio hook up question..
    By vintageb3 in forum Car Audio
    Last Post: 12-01-2004, 03:07 AM
