Results 11 to 20 of 25
Thread: External HD Question
  1. #11
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by Bugbyte View Post
    You could get a relay with a timer on it and have it shut the drive down 30 seconds after the car turns off.
    Actually, even if you pull the drive power after the Mini is asleep, you'll still get that nasty warning every time it wakes up (though your data should be safer).
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
  2. #12
    Jul 2006
    London
    If that is the case, then surely if i just eject the drive before i switch the ignition off, it will find the drive again when it comes out of sleep....?
    If this is so, is there any way i can do the eject when the machine goes into sleep...???
  3. #13
    Jul 2006
    London
    so as an example....
    This Drive Would Work?
    Is that what you are getting at, cos it is powered direct from firewire and not AC/DC
  4. #14
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by www.workingcars View Post
    I think you'll still have to unplug and plug it back. I've ejected my iPod and had my G5 go to sleep, it didn't remount when it came back. Now if you rebooted, it'd show up.
    Failure is not an option....
    It's installed by default on every version of Windows.
  5. #15
    Jul 2004
    NoVA
    You could write a Coca based App that runs in the back ground and listens for the sleep notification. The Cocoa docs say you can delay a sleep for 20 seconds while doing other tasks. So you could catch the notification and unmount the drive.
    -dave
  6. #16
    Jul 2006
    London
    Mmmmmm, i can see me taking the machine out and trying all the options for this 1.
    Still can't have it powered by invertor though, so if any other solutions come to mind apart from a firewire powered drive, or if it is poss to find an external that WILL run on the P1900 second output, then let me know.
    Drain isn;t really a concern as it would be powered off completely on return home every night, just want it quick for when i'm in and out of the car all day long.
  7. #17
    Jul 2006
    London
    Quote Originally Posted by iamgnat View Post
    -dave
    Cheers, that went straight over my head... Lol
    I'm guessing it can be done then, but not found on coming out of sleep...???
    Would that be right...???
  8. #18
    Jul 2004
    NoVA
    It looks like a good candidate. The big question (which their website doesn't answer) is what happens when the Mini sleeps. I believe that Firewire and USB are both powered during sleep (I know they used to be, haven't tried recently). If the drive continues to draw full power (I would be surprised if this is the case since no accessing is happening) while the Mini is asleep, then you run the risk of running your battery down (though the P1900 will cut the power before you are really screwed).
    -dave
  9. #19
    Jul 2004
    NoVA
    Yeah I was afraid of that
    The problem is that there isn't a big call for this, so finding someone to make you an App might be tricky.
    As far as waking from sleep (yes my iPod still charges while my PB is asleep), when I woke my PB it remounted my iPod even though I manually ejected it before putting it to sleep.
    -dave
  10. #20
    Jul 2004
    NoVA
    It apparently does not however charge while the Mini is asleep on the P1900. I did use firewire on my PB and USB on the Mini though (don't know if that makes a difference).
    -dave
  1. External Apps & DUN connection question
    By DarquePervert in forum StreetDeck
    Last Post: 05-27-2006, 12:54 PM
  2. Dvd and hard drive on same cable question
    By zetecdan in forum General Hardware Discussion
    Last Post: 07-07-2005, 01:16 AM
  3. FS: 2-40gig 2.5" laptop HD in external USB 2.0 enclosure
    By riddle14 in forum Classified Archive
    Last Post: 03-19-2005, 11:41 AM
  4. Microdrive vs. 2.5" laptop HD
    By videonerd in forum General Hardware Discussion
    Last Post: 11-14-2004, 01:09 AM
  5. Removable HD question
    By dudah85 in forum General Hardware Discussion
    Last Post: 04-17-2001, 06:58 PM
