Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: External HD Question
    Jul 2006
    London
    What will be the best way to power a western digital 320Gb external.
    I have the P1900 now, and it runs the intel mac beautifully, but i get interference with the invertor on through the screen.
    The problem i have is mainly caused because of the fact that i have 28,000 songs and 400 films that i want to have available to me at all times...
    Any help or pointers in the right direction would be really appreciated.
    AMP Creator aychamo's Avatar
    Jun 2006
    You must go on *very* long drives!
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    or just never sure about what you wanna hear or see!
    I wonder...
    What kind of power does it take? Is it an HDD in an enclosure with a 110V power adapter or is it an internal *external* hard disk that needs straight 12v/5v?
    Could you find a cheap voltage regulator and just tie it in with the ignition so it comes on at the same time as the mac?
    Jul 2006
    London
    Quote Originally Posted by aychamo View Post
    The drive i will be using is...
    THIS HARD DRIVE
    It is alot i know, but with car shows, and alot of business mileage, it is really nice to have.
    Will it connect to the secondary power output of the P1900 in any way, or will there be something else...?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    That drive says it comes with an AC adaptor cord, so you could plug it into your inverter. Did you mean that you can't do that because your inverter interferes? If so, look at the output of the AC adaptor and see what it is.
    If it's 12 volts, check the amperage. Depending on how much it draws, you may be able to use the secondary output of the P1900 to power it.
    Want to:
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by Bugbyte View Post
    I would guess it should work. The 120 is getting down converted at the brick, you are right about the amps though.
    One thing to be concerned with is that the you really don't want the drive to be powered down as that will give you the nasty "drive has been disconnected" warning. While normally that is mostly meaningless, if you are actively using the drive for music/movies then there is a higher risk of data loss (not to mention not being able to pick up where you left off the next time).
    Not sure what the best option is in that regard.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    Jul 2006
    London
    The noise of the invertor is unbearable, and is just not an option when you take into consideration the interference.
    I have tried 3 different types now, all above the correct power, but all with the same noise and interference, to the point where i am considering just binning the idea. This said, i really want to just be able to copy the updated itunes music folder across when i need to do it, and external is the only option when it comes to that size of file...!
    I'm thinking now, the only way is to contact technical for the drive manufacturer to see if they can help in any way.
    Jul 2006
    London
    Quote Originally Posted by iamgnat View Post
    i have found that as long as you exit front row BEFORE you power off or power failure the machine, it will always have resume for what you where doing in front row... Lol
    I had just been switching the mac and hard drive off at the invertor, and had no problems with that or data loss.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    -dave
    Good point. I forgot that the P1900 will just yank to power when you shut the car off. It's hard to tell if there will be issues with doing that, but my sense is you ought not to.
    You could get a relay with a timer on it and have it shut the drive down 30 seconds after the car turns off.
    Want to:
    Jul 2004
    NoVA
    Quote Originally Posted by www.workingcars View Post
    Do you already have the drive? If so, all the important information is usually written right on the power brick.
    If not, look into external drives that are powered off firewire or USB2 (look specifically for Mac compatiable ones and you probably won't need to worry about sleep issues, though it may cause more drain on the battery while it is asleep than just the Mini by itself).
    -dave
  1. External Apps & DUN connection question
    By DarquePervert in forum StreetDeck
    Last Post: 05-27-2006, 11:54 AM
  2. Dvd and hard drive on same cable question
    By zetecdan in forum General Hardware Discussion
    Last Post: 07-07-2005, 12:16 AM
  3. FS: 2-40gig 2.5" laptop HD in external USB 2.0 enclosure
    By riddle14 in forum Classified Archive
    Last Post: 03-19-2005, 10:41 AM
  4. Microdrive vs. 2.5" laptop HD
    By videonerd in forum General Hardware Discussion
    Last Post: 11-14-2004, 12:09 AM
  5. Removable HD question
    By dudah85 in forum General Hardware Discussion
    Last Post: 04-17-2001, 05:58 PM
