Sounds like the resolution or refresh rate that the Mini is currently set to don't work with the monitor. Hook it back up to your other monitor and set it to 640x480 and a "normal" refresh rate. Then try again. Once you can see the finder, then you can start playing with higher resolutions and refresh rates (it will revert back if you don't accept a change (i.e. it goes black).
OSX doesn't have drivers for monitors (neither do PCs, those drivers are for the graphics cards). That you see the Apple logo says that the Mini can use it fine, you just need to find settings that the two agree on.
Hope that helps.
-dave
LinkBack URL
About LinkBacks
Where are you mounting?
