View Poll Results: How should I mount the Mini?
Voters
15. You may not vote on this poll
  • Option A - flat glovebox floor, angled down
    2 13.33%
  • Option B - horizontal to ground
    7 46.67%
  • Somewhere else in the car besides glovebox (explain)
    6 40.00%
Results 1 to 10 of 19
Thread: Mounting Mini in 2001 Accord glovebox ideas (with pics)
    Dec 2005
    Trying to figure out how to mount my new Mini in the glovebox of my 2001 Accord. I bought an extra glovebox on ebay so I could fool around with it and screw it up a few times before hacking into my good one
    What do you think of these two mounting ideas:
    Option A: Flat on floor of glovebox - 45 degree angle to ground
    This is the most space efficient positioning in the glovebox. It has several advantages:
    - takes least space
    - looks like it's supposed to go there
    - minimal rework on the glovebox since the "base" is already there.
    Concerns:
    - poor circulation
    - odd angle to the ground (not horizontal or vertical, about 45 degree angle) ... not sure if that matters, but it doesn't "feel" right for some reason
    Option B: Parallel to ground
    Advantages:
    - better airflow all around since there is space above and below system
    - makes more sense to me for some reason to have it level like that
    Concerns:
    - a lot more work to modify glovebox?
    - wastes space
    - clearance for cables to exit back of system
    At this point I haven't carefully examined where the cables would exit with either setup so it may make this discussion irrelevant.
    Is there anything else I should be considering (in regards to mounting this in the glovebox)?
    Mar 2006
    Colorado, but Canadian!
    I remember reading somewhere about the mini's and reading CD's at angles other than the ground. Might be a consideration.
    Also keep in mind it may be flat when you open it out but when it gets stuffed in and closes it is going to be at another extreme angle.
    Aesthetically when open, I think the angle (resting on base NOT parallel to floor) looks best. Also if you will be inserting CD's and such, it seems more logical for a car environment like it should be.
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    DAMN if that isnt going to be a nice smooth and easy install!!!!!
    Well nothing is ever easy...especially when we start thinking ... wait i can do this better....... and before you know it your car runs on water and is processed through.... well anyway
    I wouldnt worry to much about angle the mini is like a laptop and will (as far as i know) run on any angle.
    If you want to put it level just for fun (it probably would improve the circulation slgihtly and might make installing wirign etc easier) It shouldnt be too hard
    Two contoured supports epoxied into the box maybe (its just what came to mind looking at the pciture)
    Well seems liek you ahve some work cut out for you! Good luck with it.
    (as cable clearence goes... theres probably some room behind the box... so a hole in the back should do it....but who knows till you upen it all up!)
    Brown 2010
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    will it where that small compartment is under the radio dash in front of shifter?
    Mar 2006
    That space is wide enough, but in my 2001, that pocket goes down a bit and where it stops is the stop of the space behind the pocket. Basically what you see is what you get. I thought I was going to put a slim dvd drive in there, and it was too long with the cables attached for comfort to give you an idea of how deep it is. Big sheet of metal right behind. It sucks.
    Good idea though.
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Why not whip out the duct tape, mount it temporarily in one position, drive around with it for a few days, and then evaluate...I think you'll uncover a clear advantage for one position by experimenting a bit...and an advantage that might not be apparent with the mini on the bench.
    Also, read Bugbyte's excellent FAQ on the installation of a mini in a car...in it, he states that the mini intakes from the bottom of the unit, so you might not want to mount it perfectly flat (although I can't see how there's a difference in mounting it that way in the glovebox than running it on a tabletop).
    Just something to consider.
    Constant Bitrate godraj's Avatar
    Jan 2006
    east coast NY
    I started workign on a pc in an accord when i started the project, but I didn't like it. Take a look at the pic of the test fits, 1 big issue with the accord glove box is that it's completely sealed when the door to it closed, so that will be a major problem. The PC board that I had fried because of the ventilation problem.
    The best place to mount it (if it will fit) is under the radio by the dc-connector. I dont' think it will fit, but if you angle it in certain way it just might. I used to leave my ipod connector there, so running wires there is really simple, you won't have to drill any holes.
    Jan 2006
    The Colony, TX
    the best place would be drop the radio down to that and put the screen and parts behind the dash like mine
    Jan 2006
    I have mine neatly tucked away under my passenger seat
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Not trying to rag on your car or anything, I do drive an Element, but...
    Failure is not an option....
    It's installed by default on every version of Windows.
  1. e46 screen mounting idea's for 7" Lilliput
    By eazyrog in forum Fabrication
    Last Post: 12-28-2008, 02:14 PM
  2. Fusion of Zaurus and '00 Accord (lots o' pics)
    By Xumbi in forum Show off your project
    Last Post: 07-12-2005, 11:47 PM
  3. Need ideas for mac mini install!
    By shizzle in forum Fabrication
    Last Post: 03-26-2005, 02:39 PM
  4. Pics of my screen-in-dash Accord project
    By mykolJay in forum Fabrication
    Last Post: 07-02-2004, 11:22 AM
  5. need ideas and pics of non-indash mounts
    By [H]Bugster in forum LCD/Display
    Last Post: 09-22-2003, 04:30 AM
