Results 1 to 10 of 15
Thread: Overheating your Mac Mini - No problem!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If you've been curious about what happens when you overheat your Mac Mini, don't worry. I've done your homework for you!
    I was on a lengthy trip this week with the Mini. My installation is particularly tight, buried in the dash, in close proximity with the heater/AC plumbing. You can check out my worklog by clicking my signature if you want all the gory details. Suffice it to say that because of the way my Mini is installed, it's actually more likely to overheat in the winter than the summer because it can suck in hot air from the heater.
    So I've always monitored this by using temp monitor lite and making sure that I keep the heater set more to the feet than the upper vents (generally a 75% feet/25% upper split). Well, I forgot to do that this time and since this is the first time I've had the heat on in the car for an extended period of time, I overheated the Mini. Here's what happens.
    It took about 35 minutes and the only warning I had was a single skip in the music about 5 minutes before overheat. I thought this was odd because I've NEVER had a skip in my audio, no matter what the conditions or load on the CPU.
    Five minutes later the screen went black and the Mini shut down like somebody pulled the power cord. I instantly realized I'd had the vents set to all upper and had the temperature on full.
    The mini docks in my dash and is removed via a lunchpail style handle I added to it. The handle is aluminum and when I reached into the dash to pull the Mini out it was almost too hot to touch! I pulled the Mini out and felt the top, bottom, sides. It felt like I'd baked it in the oven at 190 degrees.
    I set it on the seat for 15 minutes until it cooled down and re-docked it, then hit the valet switch to energize the system. After a few seconds of silence, BONG! it started without complaint. I relaunched all apps and was back online with the SMART temp reading 118 degrees. Since I've routinely run it as high as 135+ F, I just monitored it for awhile and it stablilized at around 124F. I finished the trip (another 4-1/2 hours) and returned the next day with a 6 hour run. No problems with the system at all. In fact, I'm typing this entry on the Mini right now.
    Thanks to whichever engineer decided that a thermal shutdown sensor was a good idea! It worked for me. Now, I suggest you don't test it yourself!
    Want to:
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    That's good to know, might be time to add some insulation.
    Failure is not an option....
    It's installed by default on every version of Windows.
    Mar 2006
    Colorado, but Canadian!
    That's a resiliant computer! When I first read the thread title, I was thinking some pictures with flames shooting out your vents would be below! I am glad I was wrong!
    Do you have any plans on fixing the circulation back there so that you can run your heater full blast and be ok?
    1.9in x 2.9in -- 47mm x 73mm
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by 2k1Toaster View Post
    The problem is actually that the dash piece that connects the passenger vents to the heating system leak hot air into the dash, which is where the Mini picks up its intake air.
    It's difficult to fix because the pieces don't mate until the dash is back on and there's very little room to get your hands around them to tape them up or whatever. Not only that, but you can't fix the leaks completely because the mechanism that makes the vent open or close operates using a slit in duct that leaks when it is in the open position but not in the closed position.
    Anyhow, I can still run the heat full blast. I just have about 3/4 of it coming out the feet or I close the two center vents and it comes out the driver/passenger side. With seat heaters, I've never had an issue with being cold in the car because of that.
    What I OUGHT to do is put temperature sensors in there and have the Mini monitor the intake temps and automatically adjust the air flow when it begins to warm up.
    Want to:
    Nov 2006
    You really should look into insulating your vent system. It can help with the air leaks, just add a little bit of extra insulation where the two pieces will come together. It'll probably make it harder to put together, but the end result would be worth it.
    Constant Bitrate godraj's Avatar
    Jan 2006
    east coast NY
    bugbyte, do you have the ppc version or the intel version?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Mine is PPC. Just got back from another long trip and paid very close attention to the temps as I was driving. It works quite well when you have it split between upper and lower vents. It actually runs a bit hotter when it is more biased toward the floor vents.
    The temp I'm running consistently are in the 126-135F range. It seems to be happy at that range.
    Want to:
    Nov 2006
    Amarillo, TX (formerly Albuquerque, NM until Nov 2006)
    just picked up a good piece of knowledge, and thanks to you, i didnt have to test it for myself! thanks for the pass-on..
    Jan 2006
    east coast NY
    bugbyte, i think if you had a intel, it would have fried the unit, or shut of alot quicker, becaue they run MUCH hotter. what are you using to read the temperatures?
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    i can answer to the intel bit... they perform in exactly the same way in an overheat condition. My first round of testing had an intel mac positioned on it's side in my center console which is enclosed with little ventilation and that's exactly what happened. Thermally triggered shutdown followed by a brief cooldown, then flawless operation. Still works to this day, however I've since relocated it to the glove compartment which has more air movement and sees temps closer to that of the cabin.
  1. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 05:25 PM
  2. P1900 alternative power supply for Mac Mini
    By johnsin in forum MacCar
    Last Post: 12-07-2006, 10:05 AM
  3. FS: Mac Mini and 20" Mac Widescreen
    By xanimal in forum Classified Archive
    Last Post: 09-03-2005, 06:27 AM
  4. MINI Cooper Cabrio, Mac Mini
    By FireAnt in forum Show off your project
    Last Post: 05-02-2005, 11:44 AM
  5. Replies: 0
    Last Post: 04-25-2005, 04:09 PM
