If you just want to measure you input voltage and current, spend your extra $30 on the CNX-P2140 and use the PSUmoni2140 to make these measurements.I obviously want to use the second inline fuse box for its amp and volt monitor as i think the fuse part of this box is unnecessary.
We provide "pigtail" input/output connectors that allow you to attach to your ingition wire. You'll need to search for a suitable "ignition" wire in your car.Question 1:
In general, each time you downsize from one wire gauge to a smaller gauge you'll need to add a fuse at that junction point. This is to protect shorts on the smaller wire since it would burn long before you 80A fuse popped.Question 2:
There's no good way to tell without trying. Both units tend to be electrically "noisy", however wiring will be as important, or more important, than mounting proximity.Question 3:
LinkBack URL
About LinkBacks
