I hacked the power button using the Carnetix wiring harness. It's a 'Y' harness that keeps the power button intact and gives you two wires for the P1900 to wake up the system. I soldered into the harness to provide two outputs on the back of the Mini that contact the docking mechanism so I didn't have to connect/disconnect the harness when installing or removing it in the car.
A simple SPST switch (probably momentary contact) would have been very easy to add at that point. You can see the details in my worklog (linked in my signature)
LinkBack URL
About LinkBacks
