+ Reply to Thread
Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Auto-Play iTunes on Wake Up?
    Dec 2006
    Hi. Quick question. Is there any way to have iTunes automatically play when the computer wakes up?
    Variable Bitrate natedawgg's Avatar
    Jan 2007
    Dallas
    Quote Originally Posted by timeshifter View Post
    im not sure if any of those scripts will help when just coming out of sleep. the only one there just starts itunes from boot up.
    is there any setting to allow or "force" itunes to start playing wherever it left off when put to sleep?
    Dec 2006
    yeah thats what im looking to do as well. i could have sworn theres a way to do this with applescript but I havent touched applescript in about 6 or 7 years so Im clueless at this point.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    There is. I wrote a front end in Applescript and had to solve this problem straight away. However, you have to make the Applescript into an application and have it running all the time.
    Use the 'idle handler' which loops each time there are spare cycles on the CPU. Each time you loop, check the status of iTunes. If it is paused, tell it to play.
    Of course, the only way to pause iTunes once this app is running is to quit the app or quit iTunes. You can work around it if your app is a frontend or controller for iTunes but I don't think you can if it isn't.
    The code is something along these lines (I didn't test it). You can cut and paste it into the Applescript editor, then save it as an application.
    on idle
    tell application "iTunes"
    if player state is paused or player state is stopped then
    play
    end if
    end tell
    end idle
    ***Edit - wait, it's not that simple. I tested it and the idle handler doesn't work. I'll have to investigate further when I have some time***
    Want to:
    Jan 2007
    Dallas
    ok so i did some reading up on apple script and i finally got bugbyte's code to work. Here is what you need to do to make this work. in script editior enter in
    on idle
    play
    end if
    end tell
    return 1
    end idle
    when you save this file make sure you save the script as an application and then check the "stay open" box at the bottom of the "save as" window.
    if you do everything correctly then you can run this app and it will check every second to see if itunes is paused. i checked it on my system and it seems to work great. if you have any problems pm me and i will see if i can help. thanks bug byte for your help on this.
    Jul 2006
    London
    Seems to work fine on the mac indoors, will add in the car tomorrow and test...!
    Just need it work within front row to be sure....!
    CLICK ME
    Smart Car due for completion beginning of march....
    Log with pictures to go online shortly after.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Was THAT the problem?! Return 1?!
    You know, the on idle loop is a problem. It's not stable. That's the reason we stopped work on our applescript front end. It didn't behave predictably.
    Want to:
    Jul 2006
    London
    Well, the only problem i can actually see with it at the moment, is the fact that you cannot pause iTunes at all....!
    So if you interrupt for a phone call it could cause a problem, is there a work around for the pause to still work...?
    CLICK ME
    Jan 2007
    Dallas
    Quote Originally Posted by Bugbyte View Post
    yeah actually your code worked you prob just didn't let it run long enough. while i was reading i noticed that the idle handler only checks every 30 seconds or so unless you add the "return" with the number of seconds you want the idle handler to wait before it checks again.
+ Reply to Thread
  1. Auto Disconnect From Cell Phone Without Delay......Is This Possible?
    By jmciver in forum Wireless Communications
    Last Post: 12-16-2006, 01:56 PM
  2. Skin and auto play bug...
    By the_tiger in forum CF Bug Reports
    Last Post: 10-05-2006, 12:52 PM
  3. Winamp doesn't play, but the play sign is there
    By mbowler in forum Software & Software Development
    Last Post: 08-03-2000, 07:46 PM
