Using bluetooth boost mobile as a modem on a mac
this is how you use you boost mobile phone a modem. first you need the data plan. the unlimited plan is the best. then you need a bluetooth enabled phone and bluetooth on you your mac or PC (most macs have bluetooth)
1. turn bluetooth on in phone
2. go to your network setting (system preferences network)
3. click on bluetooth
4. fill in the info
configuration: default
telephone Number: S=2#777
Account name: your 10 digit phone number
password: your pin (you use this to sign in to your boost mobile account)
5. click the advanced tap then change the modem setting to:
vendor: sprint
model: PCS vision
Make sure "enable error correction and compression in modem" is checked
Dial mode: you what to Ignore dial tone when dialing
6. hit okay
7 a phone icon will so up on the top tool bar
click it then click on "connect bluetooth"
now you are connected. is slow but it works. boost mobile will tell you that this can not be done. But you can
problems setting it up chip me at 192*145*1527
