Page 4 of 14 FirstFirst 12345678910111213 ... LastLast
Results 31 to 40 of 140
Thread: Destinator 3 Frontend v1.1
  1. #31
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    basically it dosnt work in medicar but does when i open it normally. ONly thing that loads in mediacar is the front end, also when i click one of the winamp buttons it opens a window folder in the winamp directory.
    CarPC status: iPod, 3,456,217 songs so **** you
  2. #32
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Pressing Hotkey04=Local,FE_MENU_ITEM_GPS,{CTRL},E sometimes does not close the window, especially when first starting up the frontend.
    [Edit]: Same for Hotkey05=Local,FE_MENU_ITEM_SHOWROUTE,{CTRL},F.
  3. #33
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by 0l33l
    What do you mean? It doesn't close what window?
  4. #34
    Aug 2003
    Warrington, UK
    Quote Originally Posted by Motoko
    Is this new to this version or has this always happened for you?
    The winamp thing is happening because your playlist is empty and you're trying to press play - so it asks for a file
  5. #35
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Hey can't wait for it to be re-uploaded once you've fixed it - we looking at tonight?
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  6. #36
    Aug 2003
    Warrington, UK
    Quote Originally Posted by cbyriel
    It's great nice to see some effort into this!!... one request though:
    When entering a route (address, nr, zip) with the onscreen keyboard, and you have the search field, could you make so the map is invissible, because when have entered all things the screen is very messy and not easy to read.... so basiclly make the search field bigger so it covers the whole map, instead of just looking like it's on top (which looks very odd when only 5mm of the map is vissible at the end) - so to get peace for the eye, this would be great.
    otherwise great work!
    Maybe it's just my PC, but the dialogs cover the whole screen apart from the menu bar. What resolution are you running in?
  7. #37
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Ninja Monkey
    Like I open Destinator3 and Press Control-F. It says "Warning, Route is not defined. To define route press destinate". But when I want to exit out of that screen by pressing Control-F again it won't let me, it will just keep on showing it over, and over again.
    Same thing for the GPS screen, except after a while it will close it (I use Control-E for it).
  8. #38
    Its only started to happen when i installed this new version.
  9. #39
    Aug 2003
    Warrington, UK
    That's how it was designed...I've got no use for keyboard shortcuts so I've done it the simplest way I could - by allowing a different key for each function.
    To close a dialog you'll have to assign a button the the home function.
  10. #40
    Jul 2004
    Berkeley, CA
    Oh, ok.
    Oh yeh, I still can't change between City -> Street -> Number
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  2. MediaCar, Ninja Monkey frontend and D3SDK
    By Skraggy_uk in forum Software & Software Development
    Last Post: 10-12-2004, 04:29 PM
  3. frontend
    By 00CericaRuss in forum Software & Software Development
    Last Post: 11-25-2003, 12:53 AM
  4. Docking WinAmp Visualizations in your frontend
    By qjones in forum Software & Software Development
    Last Post: 12-28-2002, 07:05 PM
  5. controlling mpg123 with a frontend
    By samael in forum Software & Software Development
    Last Post: 05-07-2001, 11:31 PM
