Page 8 of 14 FirstFirst 1234567891011121314 LastLast
Results 71 to 80 of 140
Thread: Destinator 3 Frontend v1.1
  1. #71
    The land of polar bears and nekkid blonds
    Ninja Monkey,
    I noticed "EnableTMC=Yes" in the settings.ini file, but have you seen any settings for the TMC in the SDK or do they assume that you're using a GPS reciever with built in TMC support.
    It would be nice if it was possible to use a plain USB RDS reciever.
    Many thanks,
    /M
  2. #72
    Oct 2004
    TMC testing
    NINJA,
    I've downloaded your new frond end. But don't see the TMC option.
    I have a GPS with TMC so i could test it for you. Please send the front end to test.
    What I've read in the manual (..ops ) that if you use destinator 3.1 PRO the TMC function is standing in the GPS settings window. There you can enable it. I have an installation of destinator 3.1 , when i search the files i see a exe file with TMC in the name. But I can't run it under a win32 api.
    In the SDK there is an function enabletmc haven't tried it out yet.
    I've also found the destinator c_client c++ source . Anybody interested in this see emule it was named "destinator sdk 3A"
    NINJA you're doing a good job... well done !!
    thanks.
  3. #73
    Oct 2004
    maps????
    Great job monkey...
    I am here in the us where can u get us maps????? and yes I
  4. #74
    Deactivated Diewlay Lowmo's Avatar
    Aug 2004
    Darknight, you can buy them.
    Once again, Absolutely Phenominal!
  5. #75
    Jan 2003
    Ruston, LA
    Quote Originally Posted by darkknight74
    Great job monkey...
    http://www.destinator1.com/storefron...category=3&id=
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #76
    Constant Bitrate ŠuTcH's Avatar
    Jan 2004
    Melb, Australia
  7. #77
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    WOW This is so good - and I've only just started using it! Let alone playing with the other features!
    Well done Ninja Monkey you've done a great job!!!!!
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  8. #78
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by CdRsKuLL
    ffs.. hes me just finished my skin, and he goes and releases a update.. O well lol
    heres a taster of what it 'would' of looked liked
    will add the extra functions in the next couple of days :-)
    also just a quick question.. how hard would it be to move the main_menu and the dest_menu into the middle of the screen.. this would finish the skin of wonderfully as the boxs are the same size as the 'view' menu
    cheers
    CdR
    NM could have just given the option to use the default menus that are already included in the SDK. They appear in the middle and are the same size as view!!
    Edit: The icons are all included in destinator.bmp so you could select which icon you wanted or add new ones, also you could then change the box(background) to whatever colour you wanted..etc etc.
    Edit 2: Of course I realise that there's more to your skin than just these boxes!
  9. #79
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    squigglyrulez,
    Do not promote piracy here. Support the company and actually buy the product if you are going to be using it.
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  10. #80
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    nearly finished the update to my skin, but I have come across 2 problems.. unsure if ninja can help..
    The first problem is the menu box wont quite center, and is dependent on the size of the screen, its taking the point from the bottom left corner of the pic and to make it work it would need to take it from the middle.
    The other problem it that because i'm using a white background, the text that appears in the center line doesnt show..
    If nothing can be done then I will change me skin to try and get it working right
    cheers
    CdR
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  2. MediaCar, Ninja Monkey frontend and D3SDK
    By Skraggy_uk in forum Software & Software Development
    Last Post: 10-12-2004, 04:29 PM
  3. frontend
    By 00CericaRuss in forum Software & Software Development
    Last Post: 11-25-2003, 12:53 AM
  4. Docking WinAmp Visualizations in your frontend
    By qjones in forum Software & Software Development
    Last Post: 12-28-2002, 07:05 PM
  5. controlling mpg123 with a frontend
    By samael in forum Software & Software Development
    Last Post: 05-07-2001, 11:31 PM
